MyDevices Cayenne, LoRaWAN
We are facing problem to find S76G LoRa Module in add widget, there’s available development board only for S76S, so my question is about S76G, is it supported by MyDevices Cayenne or not ?
@eptak tagging here.
You have two options for that module
Option 1:
Please use following entry in the LoRa menu
Your device then needs to send data similar to Semtech Europe Mote
See page 17: https://www.semtech.com/uploads/documents/User_Guide_LoRaMote_STD.pdf
Option 2:
Select Cayenne Low Power Payload, and send data accordingly
Hi, Thanks for the information.
As you gave options i tried Option 2, because right now i can not purchased LoRaMote, and after tried option 2. I gone through all process in TTN for connecting Cayenne LLP and everything is ok but still then there’s not showing any kind of data on Cayenne dashboard.
so what to do next? any solutions
