NCD current sensor RP 3 board read out
Has anyone some expierience with setting up the Cayenne Dashboard for reading out a NCD current sensor board.
Can this be done directly.
What code do we need to use to read out the info over the I2C interface.
Yves
can you share the link to this device.
I would like to provide my answer via the community, but I can’t login and if I check my tread, I don’t have the reply button anymore
Can my account be checked please
Groeten,
Yves Deschoenmaekers
you need to login first in https://mydevices.com/cayenne/signin/ and once in the dashboard click on community on top right corner. then again login in the community and you are good to go.
Not working, don’t have the options to reply to my treads
Groeten,
This was working before, but since a day or 2 it don’t anymore
Groeten,
can you see that you are login?
Each time I try to login in I get this
Groeten,
did you follow this steps?
Now it is working again, Thanks for the support,
no back ontopic
you requested me to put the link to the board used
connect it to arduino ,give this code a try and try to get value from the sensor. https://github.com/ControlEverythingCommunity/PECMAC/blob/master/Arduino/PECMAC125A.ino
