Need Help, can,t find other conectivity
  • Device & model you are using ( Arduino Uno with W5100 ethernet shield)
  • What dashboard are you using? (Web, Android)
    Hi everyone, need help why I can’t find other conectivity option, just virtual can choose.
You will need to select Custom Widget>Button instead of Actuators>Light to get other options.
Thank u for the fast response. But I have some problem again. How to add another LED button, I’ve try it but it seem overwrite the old one.
did you try this ? :
Yes, but does’nt work
you have to select different channel for each button and then add code to read each button:
select channel 1 for led 4 button and channel 2 for led 5 button.
CAYENNE_IN(1) // Get current value of led 4 button
int x = getValue.asInt();
digitalWrite(led_4_pin, x);
CAYENNE_IN(2) // Get current value of led 5 button
 int x1 = getValue.asInt();
digitalWrite(led_5_pin, x1);
Hi, thanks for the answer, can you please show the entire code?
//#define CAYENNE_DEBUG
#define led_4_pin 6
#define led_5_pin 7
unsigned long lastMillis = 0;
  pinMode(led_4_pin, OUTPUT);
  pinMode(led_5_pin, OUTPUT);
    lastMillis = millis();
    //Cayenne.luxWrite(2, 700);
Thank you, its work. You’re the best.
great to hear that.add a resistor between the led and pin. now you can start with much advance projects using cayenne.
OK, still need your help in the future.
