Need help with multiple arduino voltege sensor
Hi, need help to setup voltage monitor. I use 4 voltage sensor conected to analog pin 2 to pin 5 and measured 4 diferent voltage., and show up on cayenne dashboard. But the problem is the witdget seem show the same pin. Can u please help me…
> Blockquote
// #define CAYENNE_DEBUG
#define analogInput2 2
#define analogInput3 3
#define analogInput4 4
#define analogInput5 5
// Volmeter
int analogInput = A2 - A5;
float vout = 0.0;
float vin = 0.0;
float R1 = 30000.0; //
float R2 = 7500.0; //
int value = 0;
char username[] = ".................................................";
char password[] = "......................................";
char clientID[] = ".................................";
unsigned long lastMillis = 0;
  Serial.print("DC VOLTMETER");
  pinMode(analogInput2, INPUT);
  pinMode(analogInput3, INPUT);
  pinMode(analogInput4, INPUT);
  pinMode(analogInput5, INPUT);
  //Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
    lastMillis = millis();
    Cayenne.virtualWrite(2, vin , "voltage", "v");
    Cayenne.virtualWrite(3, vin , "voltage", "v");
    Cayenne.virtualWrite(4, vin , "voltage", "v");
    Cayenne.virtualWrite(5, vin , "voltage", "v");
    //Cayenne.luxWrite(2, 700);
    // read the value at analog input
    //Voltmeter
    value = analogRead(analogInput);
    vout = (value * 5.0) / 1024.0; // see text
    vin = vout / (R2 / (R1 + R2));
    if (vin < 0.50)
      vin = 0.0;
you should had continued in same topic in case of creating a new.
because you are reading from only one analog pin and
publish this value to all the 4 channels.
I used this new code, seem to be wrong. Its still show the same measured.
#define analogInput0 0
#define analogInput1 1
// Volmeter
float vout = 0.0;
float vin = 0.0;
int value = 0;
char username = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
char password = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
char clientID = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
pinMode(analogInput0, INPUT);
pinMode(analogInput1, INPUT);
Cayenne.virtualWrite(2, vin , “voltage”, “v”);
Cayenne.virtualWrite(3, vin , “voltage”, “v”);
Cayenne.virtualWrite(4, vin , “voltage”, “v”);
Cayenne.virtualWrite(5, vin , “voltage”, “v”);
//Voltmeter
if (vin < 0.05)
  vin = 0.0;
CAYENNE_OUT(2) // Get current value of analog pin 2
Cayenne.virtualWrite(analogInput2, vin);
CAYENNE_OUT(3) // Get current value of analog pin 3
Cayenne.virtualWrite(analogInput3, vin);
CAYENNE_OUT(4) // Get current value of analog pin 4
Cayenne.virtualWrite(analogInput4, vin);
CAYENNE_OUT(5) // Get current value of analog pin 5
Cayenne.virtualWrite(analogInput5, vin);
Hi @shramik_salgaonkar, could you please help. Thanks
in the above code of yours, are you reading data from all the analog pins or single pin?
I wish to read from all analog pin, could you help me with the code?
so add this for all your pins
value1 = analogRead(analogInput1);
vout1 = (value1 * 5.0) / 1024.0; // see text
vin1 = vout1/ (R2 / (R1 + R2));
and you might get error while reading multiple analog value so do dump and hold.
delay(10) ;
delay(10);
Hi, sorry it’s take too long to reply. Finally, it’s work with multiple sensor. Thank u @shramik_salgaonkar.
This is the code :
> B// This example shows how to connect to Cayenne using an Ethernet W5100 shield and send/receive sample data.
// Volmeter
float vout2 = 0.0;
float vin2 = 0.0;
float R12 = 30000.0; //
float R22 = 7500.0; //
int value2 = 0;
// Volmeter
float vout3 = 0.0;
float vin3 = 0.0;
float R13 = 30000.0; //
float R23 = 7500.0; //
int value3 = 0;
// Volmeter
float vout4 = 0.0;
float vin4 = 0.0;
float R14 = 30000.0; //
float R24 = 7500.0; //
int value4 = 0;
// Volmeter
float vout5 = 0.0;
float vin5 = 0.0;
float R15 = 30000.0; //
float R25 = 7500.0; //
int value5 = 0;
char username[] = ".......................................";
char password[] = "................................................";
char clientID[] = "..........................................................";
  if (millis() - lastMillis > 100) {
    Cayenne.virtualWrite(2, vin2 , "voltage", "v");
    Cayenne.virtualWrite(3, vin3 , "voltage", "v");
    Cayenne.virtualWrite(4, vin4 , "voltage", "v");
    Cayenne.virtualWrite(5, vin5 , "voltage", "v");
    //Voltmeter Battery
    value2 = analogRead(analogInput2);
    delay(1000) ;
    vout2 = (value2 * 5.0) / 1024.0; // see text
    vin2 = vout2 / (R22 / (R12 + R22));
    if (vin2 < 1.05)
      vin2 = 0.0;
    //Voltmeter Charger
    value3 = analogRead(analogInput3);
    delay(1000) ;
    vout3 = (value3 * 5.0) / 1024.0; // see text
    vin3 = vout3 / (R23 / (R13 + R23));
    if (vin3 < 1.05)
      vin3 = 0.0;
    //Voltmeter 12 V Output
    value4 = analogRead(analogInput4);
    delay(1000) ;
    vout4 = (value4 * 5.0) / 1024.0; // see text
    vin4 = vout4 / (R24 / (R14 + R24));
    if (vin4 < 1.05)
      vin4 = 0.0;
    //Voltmeter 24 v Output
    value5 = analogRead(analogInput5);
    delay(1000) ;
    vout5 = (value5 * 5.0) / 1024.0; // see text
    vin5 = vout5 / (R25 / (R15 + R25));
    if (vin5 < 1.05)
      vin5 = 0.0;
  Cayenne.virtualWrite(analogInput2, vin2);
  Cayenne.virtualWrite(analogInput3, vin3);
  Cayenne.virtualWrite(analogInput4, vin4);
  Cayenne.virtualWrite(analogInput5, vin5);
}lockquote
great to hear that it is working. but why you sending values two times to the the channel widget?
Hi @shramik_salgaonkar, which part you are referring to?
is same as
Well, thanks for the correction, i will revise it again.
use the first one and delete CAYENNE_OUT().
Roger that.
