New Board on development
I’m developing a new board, I’m here to gather advice and suggestions.
Notify your needs, if it is possible I implement it.
The idea is to make a practical product, ready to use, no loose wires or educational crock.
Right now it is not compatible with the Cayenne, but I’m sure it will.
CPU ATSAMD21G18 - Arduino M0 compatible,
Streep, pin to pin Arduino M0.
screw terminals
VCC from 12V to 24V
4 digital/analog Input
Digital input 12V/24V + LED
Analog 1V/FS 6.8V/FS 22V/FS
4 digital input /Output
4A Mosfet Output, protection Diode.
Direct Connector for the WiFi modem ESP8266
Direct Connector for the GSM modem SIM800L
Micro USB
Easy connect RS232 module, Relays Module, Ethernet Module, TFT touch.
That’s pretty cool! If it works with the Arduino IDE then it should work with Cayenne, however, the M0 is not supported yet.
Yes, Arduino IDE, arduino shield, I hope soon Cayenne.
@x-giorgio-x @ats1080s M0 is not ‘officially’ supported yet in Cayenne, but only because there is not UI for adding the M0.
I have tested the M0 using the Arduino.ORG IDE and it works in Cayenne. I just selected the Uno board in Cayenne and the M0 board in the Arduino.ORG IDE.
http://www.gevaelettronica.it/shop/index.php?id_category=3&controller=category&id_lang=1
Micro USB
Pin to pin Arduino M0.
VCC from 7V to 30V
Digital input Vcc + LED
Digital input Vcc + LED + Protection diode
4A Mosfet Output Vcc, protection diode.
Optional:
WiFi modem ESP-01
GSM modem SIM800L
Bluetooth module HC-06
RS232 DB9 module
Relays Module
Ethernet Module
TFT touch
LIN Bus
Pity GSM is being TOTALLY phased out in Australia…so many SIM800 based devices just cant be used here soon!
I also added Lipo battery and charger.
Even in the US the bands are different from Europe.
However, this form has many bands, I think that some will work.
Quad-band: AutoBand, GSM 850, EGSM 900, DCS 1800, PCS 1900.
Compliant to GSM Phase 2/2+
Class 4 (2W) at GSM 850 and EGSM 900
Class 1 (1W) at DCS 1800 and PCS 1900
GPRS multi-slot class 12
GPRS data downlink transfer: max. 85.6 kbps
GPRS data uplink transfer: max. 85.6 kbps
Coding scheme: CS-1, CS-2, CS-3 and CS-4
PAP protocol for PPP connect.
Integrate the TCP/IP protocol.
Support Packet Broadcast Control Channel (PBCCH)
CSD trasmission rates: 2.4, 4.8, 9.6, 14.4 kbps
Support SIM card: 1.8V, 3V
Arduino GEVA ZERO M0 Compatible
CPU ATSAMD21G18 - Arduino ZERO M0 compatible.
Micro USB.
Pin to pin Arduino ZERO - M0.
Removable Terminals.
VCC, Input, Output 7V to 30V
4 terminals, Digital Input /Analog Input
Digital input with LED, need to bring VCC.
Analog input 1V fs, 6.8V fs, 22V fs
4 terminals, Digital Input / Digital Output
Digital input with LED + Protection diode, , need to bring VCC.
9A Output Mosfet Vcc, protection diode. We advise you not to exceed 6A
Optional:
WiFi modem ESP-01 ESP8266
GSM modem SIM800L
Bluetooth module HC-09
RS232 DB9 module
LiPo Battery and Battery Charger
Ethernet Module
TFT touch
LIN Bus IC - Atmel ATA663211 – Need to be solder on the PCB
Provided with the ZERO bootloader
If you want the M0 bootloader, you have to request it, keep in mind that D2 and D4 are exchanged.
A to Z, Aw to Dw, Ab to Db, Vo, Are soldering Jumper, see table for their use.
Avaiable for sell.
link
