New problem with scheduling
in “edit event” in the scheduling, if the event is set to “turn on” and the load is already on, the load is turned off and on “turn off” if the load is already turned off. account of the state of the load that he also knows.
Here is the code:
CAYENNE_IN(1)
digitalWrite(INGRESSO1, HIGH);
CAYENNE_IN(2) //da Cayenne per comandare il pulsante su INGRESSO2
digitalWrite(INGRESSO2, HIGH);
CAYENNE_IN(3) //da Cayenne per comandare il pulsante su INGRESSO2
digitalWrite(INGRESSO3, HIGH);
CAYENNE_OUT(1) //virtuale per lo stato dei relè o lo stato della scheda
Cayenne.virtualWrite(1, Pulsante1);
CAYENNE_OUT(2) //usata quando l’ingresso è usato come pulsante in Tele2
Cayenne.virtualWrite(2, Pulsante2);
CAYENNE_OUT(3) //usata quando l’ingresso è usato come pulsante in Tele3
Cayenne.virtualWrite(3, Pulsante3);
i did not understand what you are saying.
Also post the entire code and not the a small part of it.
