Newbie needs help with ESP8266, HX711 and a load cell
#22
I’m quite pleased with my Cayenne now. It shows weight, temperature, humidity, uptime and RSSI. However, it would be nice with a battery indicator as well. Is it possible to create one in Cayenne and if so, is there any example code somewhere or someone who can help? I am using EPS8266 Wemos D1 mini Pro.
#23
google search to read battery voltage and see first without adding cayenne you can read battery voltage.
here are some post from community Battery Widget and ESP8266 Sleeping Temperature Station
#24
Thanks for support. I’ll check this out.
#26
Hi, you inspire me for a project that control hives in various place.
I am stuck with the weight sensor because i can’t have solid reading. How you manage it? I’m using load cell (10 kg for testing) + hx711 + wemos d1 r2.
#27
can you post the code you are using and first of all solder the pins correctly to HX711.
#28
#include “HX711.h”
// HX711.DOUT - pin #d4
// HX711.PD_SCK - pin #d3
HX711 scale(D4, D3); // parameter “gain” is ommited; the default value 128 is used by the library
Serial.begin(115200);
Serial.println(“HX711 Demo”);
scale.set_scale(); // this value is obtained by calibrating the scale with known weights; see the README for details
scale.tare(); // reset the scale to 0
Serial.print("put know weight);
delay(5000);
Serial.print(":calibration factor is\t");
float fattore= scale.get_units(10)/1000;
Serial.print(fattore);
scale.set_scale(fattore);
Serial.println(“Readings:”);
Serial.print(“one reading:\t”);
Serial.print(scale.get_units(), 1);
Serial.print("\t| average:\t");
Serial.println(scale.get_units(10), 1);
scale.power_down(); // put the ADC in sleep mode
delay(5000);
scale.power_up();
#29
The pins are solder correctly and strong i think, i will post a photo tonight
#30
#31
Unless I’m missing something, your readings are not varying by more than 1%. How accurate is the device? (precision!=accuracy)
#32
I don’t have a datasheet, but the cell come from a kitchen balance that have accuracy reading (+ - 100 grams is too much)!
#33
From your screen shot it’s only ±10 grams, unless I’m not understanding it. But like I said in the last post, just because it has 1 digit precision does not mean it is 1 digit accurate and vise versa. Here is a good read about it https://allsensors.com/engineering-resources/white-papers/accuracy-and-precision-for-mems-pressure-sensors
#34
Now my Beehive scale has been running 10 weeks under real conditions. Everything has worked well so far.
Now, I wonder if it is possible to arrange some kind of floating trigger. It would bee nice with a warning if the weight suddenly drops about 2 kg or more. It would be a good indication that I had a bee swarm. I’m thinking of a floating trigger that automatically adjusts 2 kg below the total weight. I know I can set triggers manually, but then I have to adjust it every day.
#35
what do you mean by this. can you provide more details?
#36
Hmm … how should I explain … let’s say that the wave shows 80 kg and I want it to alert if the weight drops to 78 kg. If the wave shows 85 kg, I would like it to alert if the weight drops to 83 kg. If a swarm leaves the Beehive, I get a message and can catch the swarm. A normal swarm weighs approximately 2 - 5 kg.
#37
something like this:
x1 = 80;      //read the value from the senso.
if ( x2 != x1)  //see whether x1 has changed.
x2 = x1;
x = x2 - x1;
if ( x == 2)
cayenne.virtualWrite(1,1,"digital_sensor", "d");
this is the flow you have to use, you might have to do the neccesay changes in this code.
#38
ok, will try it after this season.
Thanks for support.
