NKE Watteco THr - Dashboard readings missing
I finally managed to create my LoRa devices (NKE Watteco) and see it on the dashboard.
However, only the GPS and RSSI readings are showing up. This sensor device is sending temperature, luminosity, and humidity information, but none is showing up.
Any advise?
Hi @osinno,
Welcome to the Cayenne community! What networking are you using?
@croczey @eptak, looping you guys in here…
If you mean which Network server, I am using Actility NS.
BR
Hi @osinno,
Can you please send me the DevEUI for your device? If you don’t want to post it on the forum, you can email it directly to me at croczey@mydevices.com.
I can use that number to check our logs and see where the problem is.
Thanks,
Camrin
