No data from Kerlink SPN
  • Device : FTD Adeunis 0018b20000000ba8
  • What dashboard are you using? (Web)
Even if I got frames from the FTD on the Kerlink SPN, there is no data on the dashboard. I tried with a Semtech LoRaMote (0000000011223344) as well but I got the same issue.
Thanks,
Vincent.
For the Adeunis device, I do see frames hitting our logs (it looks like the format has changed a few times, maybe you were fiddling with it), but for the most part they seem valid to our decoder. A couple examples:
9e1b48091740001354212313130fb2
decodes to:
        "channel": 0,
        "type": "temp",
        "unit": "c",
        "value": 27,
        "name": "Temperature"
        "channel": 1,
        "type": "digital_sensor",
        "unit": "d",
        "value": 0,
        "name": "Shock"
        "channel": 2,
        "unit": "d",
        "value": 0,
        "name": "Button"
        "channel": 3,
        "type": "gps",
        "unit": "m",
        "value": [
            48.152899999999995,
            -1.5903333333333334,
        "name": "GPS"
        "channel": 4,
        "type": "batt",
        "unit": "p",
        "value": 87,
        "name": "Battery"
8f1d36340fa92602
decodes to:
        "channel": 0,
        "type": "temp",
        "unit": "c",
        "value": 29,
        "channel": 1,
        "unit": "d",
        "value": 0,
        "name": "Shock"
        "channel": 2,
        "unit": "d",
        "value": 0,
        "name": "Button"
        "channel": 4,
        "type": "batt",
        "unit": "p",
        "value": 87,
        "name": "Battery"
The payloads have stopped for about an hour as of my writing this post, but based on those, I’d expect to see widgets auto-created on your dashboard. The only reason I can think of they might not have appeared is if the server trouble mentioned by @bestes here. I believe things are in a better state by now though they are still investigating to make sure this doesn’t happen again. I’d be interested if your data is displaying now for this device now that things are stable again.
For the Semtech device, I see/think the same thing (valid payloads until about an hour ago)
Ex: 002754062d020c36447bf2fede870000 decodes to:
        "channel": 1,
        "type": "temp",
        "unit": "c",
        "value": 15.81,
        "channel": 2,
        "type": "bp",
        "unit": "hpa",
        "value": "1007",
        "name": "Barometer"
        "channel": 3,
        "type": "batt",
        "unit": "p",
        "value": "21",
        "name": "Battery"
        "channel": 4,
        "type": "gps",
        "unit": "m",
        "value": [
            48.15293170844694,
            -1.590120792388916,
        "name": "GPS"
