NodeMCU ESP8266 + DS18B20 need help
First steps and need some help. From serial monitor I get : “vw 1 temp,c=%.3f”
My code:
#define CAYENNE_DEBUG
#include <ESP8266WiFi.h>
#include "CayenneDefines.h"
#include <OneWire.h>
#define VIRTUAL_PIN V1
const int tmpPin = 0;
OneWire oneWire(tmpPin);
char token[] = "token";
char ssid[] = "ssid";
char wifiPassword[] = "pass";
  Serial.begin(115200);
  Cayenne.begin(token, ssid, wifiPassword);
  sensors.begin();
  // do something
CAYENNE_OUT(VIRTUAL_PIN)
  Cayenne.celsiusWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
CAYENNE_CONNECTED()
  CAYENNE_LOG("Connection established");
I use resistor for DS18B20.
Welcome to Cayenne!
Are you getting any values on the dashboard, or nothing at all?
On the web it shows minus, on mobile 0.00
I believe Celsius / Fahrenheit . write currently doesn’t work on arduino. You have to use virtual,write still, this is the code that’s working for me
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
Thanks! It works.
For everyone to try (for copy/paste) Celsius values for two parallel DS18B20 (NodeMCU D3 (GPIO0)):
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
//const int tmpPin1 = 1;
//OneWire oneWire1(tmpPin1);
//DallasTemperature sensors1(&oneWire1);
  sensors.begin();
  // do something
CAYENNE_OUT(V1)
  //Cayenne.virtualWrite(VIRTUAL_PIN, sensors.getTempCByIndex(0));
  Cayenne.virtualWrite(VIRTUAL_PIN1, sensors.getTempFByIndex(0));
CAYENNE_OUT(V2)
  Cayenne.virtualWrite(VIRTUAL_PIN2, sensors.getTempFByIndex(1));
CAYENNE_CONNECTED()
To get correct values in Celsius, I had to get Fahrenheit value in NodeMCU and set Celsius in widget. To get correct Fahrenheit in widget, you should change F to C:
to: Cayenne.virtualWrite(VIRTUAL_PIN1, sensors.getTempCByIndex(0));
Hi
I used the codes above and I am getting the C info on my Cayenne dashboard as F. I am not sure what I am doing wrong, would appreciate any hep here.
My code:
char password[] = "pass";
  sensors.begin();
  // do something
CAYENNE_OUT(V1)
  Cayenne.virtualWrite(V1, sensors.getTempCByIndex(0));
CAYENNE_CONNECTED()
And my dashboard:
Read the end of my last post. F in code = C in widget and vice versa.
