NodeMCU Esp8266 + HC-SR04
About This Project
I have been trying to get a simple code to integrate HC-SR04 ultrasonic sensor to ESP8266 and show the distance on the Cayenne dashboard. There are a few posts on Cayenne similar to this that was done, but couldn’t find one with just HC-SR04 and a NodeMCU so I decided to get it done myself, although I don’t know why I did it, lets just say for the fun of it :slight_smile:
I am not a coder, so this might or might not work for others, it worked for me, would look forward to others’ feedback. In the code that I have is what I have put together from a few places and saying that the code might not be perfect. Also, from the Cayenne widget if I add it as a value and choose Inch as the unit, it doesn’t show me the correct value. I have added it using analog distance on virtual pin.
What’s Connected
  1. NodeMCU ESP 12-E
  2. HC-SR04
Triggers & Alerts
I built this and pointed the sensor to my door, so in the evening the moment I open my door after coming back from work the lights will switch on using trigger. I am sure there are other ways to do it like using a PIR sensor, but I had a HC-SR04 lying around and had to do some justice to it.
Dashboard Screenshots
##Code
// #define CAYENNE_DEBUG
#include <ESP8266WiFi.h>
#include "CayenneDefines.h"
#include "Ultrasonic.h"
#define VIRTUAL_PIN V2
#define TRIGGER 5
#define ECHO    4
// NodeMCU Pin D1 > TRIGGER | Pin D2 > ECHO
char token[] = "xxxxxxx";
char ssid[] = "xxxxxxx";
char password[] = "xxxxxxx";
Ultrasonic ultrasonic(5, 4);
  Serial.begin (9600);
  pinMode(TRIGGER, OUTPUT);
  pinMode(ECHO, INPUT);
  pinMode(BUILTIN_LED, OUTPUT);
  // do something
CAYENNE_OUT(V2)
  long duration;
  int distance;
  digitalWrite(TRIGGER, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGGER, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHO, HIGH);
  distance = ((duration/2) / 29.1) *  0.393701;
  Serial.print(distance);
  Serial.println("in");
  delay(1);
  Cayenne.virtualWrite(V2, distance);
