Not able to get DS18B20 sensor to work with ESP8266
I am unable to read out Temperature data from a DS1820 sensor, connected to Virtual Pin 7. I have a temperature widget defined for Pin 7 and it just shows a blank value. The problem seems to be that my function “CAYENNE_OUT(7)” is never called (verfied by a Serial.printl() at the start of the function). CAYENNE_IN functions to switch on and off LEDs work fine. This is my code (only the relevant parts):
#include <OneWire.h>
OneWire oneWire(4);
sensors.begin();
pinMode(D5, OUTPUT);
digitalWrite(D5, HIGH); // LED to indicate that setup is running
delay (1000);
digitalWrite(D5, LOW);
CAYENNE_OUT(7)
Serial.println(“Cayenne_out7”); //check whether the function has been called
Cayenne.celsiusWrite(7, sensors.getTempCByIndex(0));
Serial.println (sensors.getTempCByIndex(0));
any idea what is wrong with it?
welcome to cayenne community @mike2506red
if possible can you upload the entire code you are using.
as in the above code you have not include cayenne library.
Sure - here it is - everything works, except for the CAYENNE_OUT() function.
//#define CAYENNE_DEBUG
#include <RCSwitch.h>
char ssid[] = "xxxx";
char wifiPassword[] = "yyy";
char username[] = "uuuu";
char password[] = "ppp";
char clientID[] = "ccc";
unsigned long lastMillis = 0;
boolean Ledflash = true;
boolean Blink = false;
RCSwitch mySwitch = RCSwitch();
OneWire oneWire(4);
  sensors.begin();
  delay (1000);
  mySwitch.enableTransmit(2); // Pin "D4" = GPIO2 !!
//	if (millis() - lastMillis > 10000) {
	//	lastMillis = millis();
	//	Cayenne.virtualWrite(0, lastMillis);
	//	Cayenne.celsiusWrite(1, 22.0);
	//	Cayenne.luxWrite(2, 700);
		Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
   if (Blink) {
   digitalWrite(D5, Ledflash);
   Ledflash =! Ledflash;
  //delay(100);
CAYENNE_OUT(7)
  Serial.println("Cayenne_out7");
CAYENNE_IN(5){
  int currentValue = getValue.asInt(); // Hole Wert 0 oder 1
  if (currentValue == 0) {
  Blink = false;
  } else {
  Blink = true;
 //digitalWrite(D5, getValue.asInt());
CAYENNE_IN(2) // Funksteckdose Hof über Virtual Pin 2
  Serial.println("Cayennein2");
    for(int i=0; i<4; i++){
    mySwitch.switchOff("00100","00101");
   // Serial.println("switch off");
    delay(50);
  } else {
    mySwitch.switchOn("00100","00101");
   // Serial.println("switch on");
    delay (50);
CAYENNE_IN(6) // Funksteckdose Teich über Virtual Pin 6
    mySwitch.switchOff("00100","01000");
    delay(50);
  } else {
    mySwitch.switchOn("00100","01000");
    delay (50);
CAYENNE_IN(4) // Funksteckdosen Garten über Virtual Pin 4
    mySwitch.switchOff("00100","00100");
    delay(50);
  } else {
      mySwitch.switchOn("00100","00100");
    delay (50);
//CAYENNE_IN_DEFAULT()
//	CAYENNE_LOG("CAYENNE_IN_DEFAULT(%u) - %s, %s", request.channel, getValue.getId(), getValue.asString());
char ssid[] = "ssid";
int x;
OneWire oneWire(4);
sensors.begin();
delay (1000);
mySwitch.enableTransmit(2); // Pin “D4” = GPIO2 !!}
Cayenne.virtualWrite(7, x);
x =sensors.getTempCByIndex(0);
@mike2506red try the above code.
you dont have to add CAYENNE_OUT.
Thank you Shramik! This worked - even though I don’t completly understand why :slight_smile:
So I guess I have to use CAYENNE_IN(Virtual_pin) functions only when I want to read data from a switch or button and then I have to add this button from the dashboard. When I want to
display something, the code should go to the main body of the loop() function and I should not add the widget from the dashboard, instead rely on the Cayenne.virtualWrite() function to put it there.
You’ve basically nailed it @mike2506red. To put it slightly more broadly, when using our MQTT connectivity, you only need to create widgets on the web dashboard for actuators, and then have appropriate code to handle them on the device side. For sensors you use virtualWrite() statements which when run will auto-create a temporary widgets which can then be made permanent and customized via the web (or mobile) dashboard.
@mike2506red you are absolutely right and @rsiegel has given all you need.
Hey @mike2506red,
What are you using your ESP8266 + DS18B20 for? :slight_smile:
~B
Simple Home automation application. I have a banana and a palm tree in my garden and they are not made for winters in the Black Forest. When temperatures drop below -5°C the 8266 would switch on a heating device via an RC controlled plug. Information on temperature (and total #hours heating maybe) is fed back to the Cayenne dashboard. I tried last year with a simple thermostat-controlled heater, but that one was heating too much and one of the plants died. Still unclear how the 8266 and WLAN will behave at very low temperatures and potentially under snow (in a waterproof housing - of course). I guess I will find out…
