Not receiving data from nodemcu to cayyene
Im using nodemcu and dht11 tp semd humidity data to Cayyene.
Using arduino as IDE.
My sketch is here ::
#include "DHT.h"        // including the library of DHT11 temperature and humidity sensor
#define DHTTYPE DHT11   // DHT 11
#define dht_dpin 0 //D3
DHT dht(dht_dpin, DHTTYPE);
float h;
float t;
char ssid[] = "bla..bla";
char wifiPassword[] = "bla..bla";
char username[] = "bla..bla";
char password[] = "bla..bla";
char clientID[] = "bla..bla";
void setup(void)
  dht.begin();
  Serial.println("Humidity and temperature\n\n");
  Serial.println("LOOP\n\n");
      h = dht.readHumidity();
      Serial.print("Current humidity = ");
      Serial.print(h);
      if (WiFi.status() == WL_CONNECTED) { Cayenne.loop(); }
CAYENNE_OUT_DEFAULT() //
    float h1 = dht.readHumidity();
  Cayenne.virtualWrite(0, h1);
After successfully compile and upload im can see by serial log that wifi and cayyene are connected successfully but there are no data on Cayyene 's device.
any help appreciate.
float h;
float t;
unsigned long lastMillis = 0;
void setup(void)
  dht.begin();
      Serial.print(h);
    lastMillis = millis();
  Cayenne.virtualWrite(0, h, "rel_hum", "p");
Thanks man.
