Online Offline Trigger ESP8266 not working
Hello Guys,
I have a Wemos D1 running on Cayenne and code is below, temperature triggers works just fine, I can get e-mail and SMS alarms when temperatura is above or below, but, the Online/Offline trigger doesnt work, any idea?
//#define CAYENNE_DEBUG
char ssid[] = “XXX”;
char wifiPassword[] = “XXX”;
char username[] = “XXX”;
char password[] = “XXX”;
char clientID[] = “XXXXXX”;
unsigned long lastMillis = 0;
// First we include the libraries
#include <OneWire.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 4
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
float temp_0;
float temp_1;
Serial.println(“Dallas Temperature IC Control Library Demo”);
// Start up the library
sensors.begin();
sensors.requestTemperatures(); // Send the command to get temperature readings
temp_0 = sensors.getTempCByIndex(0);
temp_1 = sensors.getTempCByIndex(1);
lastMillis = millis();
Cayenne.virtualWrite(8, temp_0);
Cayenne.virtualWrite(9, temp_1);
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
I see you made a post in another thread. I don’t think the online/offline triggers work. @rsiegel can you confirm?
Confirmed, right now the Online/Offline triggers work for device connected as ‘Rasperry Pi’ or ‘Arduino’, but not devices connected as Bring Your Own Thing / MQTT or LoRa.
