Pca9685 hz adjustment
  • Device & model you are using Pi 3
  • What dashboard are you using? (Web, and Android)
    I am currently using a pca9685 with a meanwell ldd to control some leds for an aquarium. I am having an issue with the lights flickering. The meanwell ldd is rated for. 100-1000hz. What is the default frequency that is used by cayenne and can the frequency be changed? If so how do i change the frequency.
It’s not as easy as adding it though the dashboard, but as a workaround you can use the MQTT API to send values to your pca9685. Let me know if you have any questions.
