PH sensor code in cayenne!
Hi guys. Good morning.
I would like know if have a custom code to add a PH sensor in cayenne with arduino.
Thank you…
Hi
Do you have any sample code with output on serial monitor?
What PH sensor do you have?
Hi.
Yes, I´m utilizing this code
This sample codes is for testing the pH meter V1.0.
Editor : YouYou
Date : 2013.10.21
Ver : 0.1
Product: pH meter
SKU : SEN0161
#define SensorPin 0 //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00 //deviation compensate
unsigned long int avgValue; //Store the average value of the sensor feedback
pinMode(13,OUTPUT);
Serial.println(“Ready”); //Test the serial monitor
int buf[10]; //buffer for read analog
for(int i=0;i<10;i++) //Get 10 sample value from the sensor for smooth the value
buf[i]=analogRead(SensorPin);
delay(10);
for(int i=0;i<9;i++) //sort the analog from small to large
for(int j=i+1;j<10;j++)
if(buf[i]>buf[j])
int temp=buf[i];
buf[i]=buf[j];
buf[j]=temp;
avgValue=0;
for(int i=2;i<8;i++) //take the average value of 6 center sample
avgValue+=buf[i];
float phValue=(float)avgValue5.0/1024/6; //convert the analog into millivolt
phValue=3.5
phValue+Offset; //convert the millivolt into pH value
Serial.print(" pH:");
Serial.print(phValue,2);
Serial.println(" ");
digitalWrite(13, HIGH);
delay(800);
digitalWrite(13, LOW);
And to add in cayenne I was using this code!
Cayenne Ethernet Example
This sketch connects to the Cayenne server using an Arduino Ethernet Shield W5100
Steps:
include <CayenneEthernet.h>
#define SensorPin 1 //pH meter Analog output to Arduino Analog Input 0
char token[] = “token”;
Cayenne.begin(token);
pinMode(13,OUTPUT);
delay(10);
if(buf[i]>buf[j])
int temp=buf[i];
buf[i]=buf[j];
buf[j]=temp;
avgValue=0;
avgValue+=buf[i];
phValue=3.5
delay(800);
But when I access my dashboard, I get absurd values.
I’m using a Millivoltmeter V1.0
Try this.
#include <CayenneEthernet.h>
float phValue;
char token[] = "token";
    delay(10);
        if(buf[i]>buf[j])
          int temp=buf[i];
          buf[i]=buf[j];
          buf[j]=temp;
  avgValue=0;
  avgValue+=buf[i];
  phValue=(float)avgValue*5.0/1024/6; //convert the analog into millivolt
  phValue=3.5*phValue+Offset; //convert the millivolt into pH value
CAYENNE_OUT(V0)
  Cayenne.virtualWrite(V0, phValue);
I get this.
Can the Cayenne transmit the values of the PH meter?
Yes, Cayenne can transfer any value.
Do you have the sensor connected correctly?
I tested it on my Arduino and it works right.
Yes. I check the connections, and give me again the same values.
what example do you choose?
And what data sensor do you use?
Ok. i’m appreciate. Thank you so much.
