Pi is Offline
Sorry for the late reaction, but i was to busy to work on it.
here are the out come of the two things you acked.
  1. ps axy | grep python
root 892 1.7 1.4 35868 13580 ? Sl Jun02 113:55 /usr/bin/python3 -m webiopi -l /var/log/webiopi -c /etc/webiopi/config
root 15613 0.0 0.1 4284 1848 pts/0 S+ 20:40 0:00 grep python
root 19114 6.1 2.7 144520 26336 ? Ssl Jun04 177:32 /usr/bin/python3 -m myDevices -P /var/run/myDevices.pid
and the second one
2016-06-06 20:41:59 - myDevices - INFO - Memory usage : 5794 size: 32724
2016-06-06 20:41:59 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=9191.72, ru_stime=1467.62, ru_maxrss=32724, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=52398828, ru_majflt=0, ru_nswap=0, ru_inblock=0, ru_oublock=589048, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=4196846, ru_nivcsw=718431)
2016-06-06 20:41:59 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2016-06-06 20:42:00 - myDevices - INFO - ExecuteMessage: 3
2016-06-06 20:42:00 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2016-06-06 20:42:32 - myDevices - INFO - SendHistoryData previously SendFailed items:
2016-06-06 20:42:33 - myDevices - INFO - myDevices cloud disconnected
2016-06-06 20:42:34 - myDevices - ERROR - Stop not connected
2016-06-06 20:42:38 - myDevices - ERROR - SendMessage fail
2016-06-06 20:43:32 - myDevices - INFO - SendHistoryData previously SendFailed items:
2016-06-06 20:44:32 - myDevices - INFO - SendHistoryData previously SendFailed items:
2016-06-06 20:44:45 - myDevices - INFO - Daemon failure handling110
2016-06-06 20:44:45 - myDevices - ERROR - Start failed: cloud.mydevices.com:8181 Error:[Errno 110] Connection timed out
Hope you can find some thing.
All way’s willing to help
Albert
Sorry, moved your post to a new topic by accident.
I’m not sure what error 110 is but below that it says Connection timed out so I would assume there is either a firewall or connection issue. Can you try everything listed here? Troubleshooting Pi Showing Up as Offline in Dashboard
Yes, i noticed i have answered againg on the other topic, because i thought that my replay was not send, sorry for that.
I will replay with an answer on your question but i can come may be om Thursday evening , but let you known what it will be
With reguards,
Albert
