PIR sensor with door sensor
int ledPin1 = 13;                // choose the pin for the LED
int ledPin2 = 12;
int ledPin3 = 11;
int ledPin4 = 10;
int inputPin = 9;               // choose the input pin (for PIR sensor)
int inputPin2 = 8;
int buzzerPin = 7;
int switchPin = 6;    //pin for door sensor1
int switchPin2 = 5;   // pin for door sensor2
int pirState1 = LOW;
int pirState2 = LOW;
int val = 0;
int val2 = 0;
int magnetState = LOW;
int magnetState2 = LOW;
int magnetValState = 0;
int magnetValState2 = 0;
  pinMode(ledPin1, OUTPUT);      // declare LED as output
  pinMode(ledPin2, OUTPUT);      // declare LED as output
  pinMode(ledPin3, OUTPUT);
  pinMode(inputPin, INPUT);     // declare sensor 1 as input
  pinMode(inputPin2, INPUT);    // declare sensor 2 as input
  pinMode(buzzerPin, OUTPUT);
  pinMode(switchPin, INPUT);
  pinMode(switchPin2, INPUT);
  digitalWrite(switchPin, HIGH);
  digitalWrite(switchPin2, HIGH);
  Servo1.attach(servoPin);
  val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(ledPin1, HIGH);  // turn LED ON
    magnetValState = digitalRead(switchPin);
    if (digitalRead(switchPin) == HIGH) {
      digitalWrite(ledPin2, HIGH);
      delay(1500);
      digitalWrite(ledPin2, LOW);
      delay(1500);
      digitalWrite(buzzerPin, HIGH);
      Serial.println("Door brake!");
    if (pirState1 == LOW) {
      // we have just turned on
      Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState1 = HIGH;
    // check sensor 2 after delay
    val2 = digitalRead(inputPin2);
    if  (val2 == HIGH) {
      digitalWrite(ledPin3, HIGH);
      magnetValState2 = digitalRead(switchPin2);
      if (digitalRead(switchPin2) == HIGH) {
        digitalWrite(ledPin4, HIGH);
        delay(50);
        digitalWrite(ledPin4, LOW);
        delay(50);
      if(pirState2 == LOW) {
        Serial.println("Motion from sensor 2 detected!");
        pirState2 = HIGH;
    } else {
    digitalWrite(ledPin1, LOW); // turn LED OFF
    delay (50);
    digitalWrite(ledPin2, LOW); // may be already
    //playTone(0, 0);
    delay(50);
    digitalWrite(ledPin3, LOW); // turn LED OFF
    delay (50);
    digitalWrite(ledPin4, LOW); // turn LED OFF
    delay (50);
    if (pirState1 == HIGH) {
      // we have just turned of
      Serial.println("Motion ended!");
      pirState1 = LOW;
    if (pirState2 == HIGH) {
      pirState2 = LOW;
how can i combine two pir sensor with door sensor??
can anyone help me…
Hi @irdain94,
Can you explain a little more what you are trying to do? You want to add two PIR Motion sensors and a door sensor on an Arduino?
@bestes I think he probably wants to use his existing code with Cayenne, but correct me if I’m wrong there @irdain94
It’s easy enough to “port” it to Cayenne, basically just add a few lines. Can you tell us what board you are using and how you are connecting it to the internet?
