Plug and play PH level sensor for use with cayenne?
Is there a plug and play PH level sensor for use with cayenne?
Not that I’m aware of for Raspberry Pi. We’re working on Arduino integration right now. Might be easier to get the code for a PH sensor, hook it up to an Arduino, and get the data there. Wish I could be more help. We’re working on some features that will give you the ability to bring on any sensor you want.
Thats cool, grovepi has a nice PH sensor so if you get their board and sensors going it would work perfect.
leopi ph sensor looks good too since it says it has 1wire and the other data outputs available.
LeoPhi USB enabled Arduino pH sensor interface
any up dates on ph sensor for arduino thanks
What model are you using? I can order one and see if I can get it working.
