Problem in Cayenne first project: Led on/off with Arduino Uno + Ethernet Shield W5100
Hello, this is my first project with Cayenne,I hope you can help me with this: I have a problem to light on and off a led that is connected to pin digital 2 of the shield, after I follow all the instructions and I am on the dashboard adding a device/ actuator/ light/ light switch/ here in connectivity only appears option virtual and I saw in many videos that it should appear the option digital so I can select below the pin D2 and make it work but it doesn’t.
Before this like I said, I already have:
  • Connected my Ethernet Shield (on top of my Uno)
  • Installed Arduino IDE
  • Added Cayenne Library (I selected version 1.2.0)
  • Selected my board and my port
    By the way, after doing this and clicked next, it appeared this (username, password, clientID):
    Instead of this (like I saw in many videos that only works when option token appears here):
    Then I selected Arduino Uno/ Ethernet Shield W5100 sketch and appeared this code:
      Steps:
      1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
      2. Compile and upload the sketch.
      3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
      char username[] = "";
      char password[] = "";
      char clientID[] = "";
      CAYENNE_OUT_DEFAULT()
      	//Cayenne.luxWrite(2, 700);
      CAYENNE_IN_DEFAULT()
That’s all, until now I can’t put my led on/off. Hope you can help me.
after uploading the code was your board connected to cayenne?
adding a button widget to turn on a led, you add button widget on your dashboard with channel 1 (virtual connectivity) and then use below code to read the value of the button :
 CAYENNE_IN(1)
	int x = getValue.asInt();
        digitalWrite( led_pin, x);
where the value of channel 1 button is stored in x. “led_pin” is the digital pin 2 of arduino where the led is connected and you use digitalWrite to turn on off led.
Thank you very much for the help, it works now. One final question please: why doesn’t appear the option digital? Is this the way the new version works, without the option digital now?
Yes… this is how cayenne MQTT version works.
I have exactly the same problem can you give me details about what you’ve done. Step by step please because I’m a beginner.
what should I do here?
Sure, first click in sketch file, then follow the steps of the comment block on top of the code:
  • put a number for the channel (in your dashboard image): I put 1
  • choose an icon (in your dashboard image): I choose light
  • Now in the line #define VIRTUAL_CHANNEL undefined (in Arduino IDE after copy/paste) : replace undefined for 1
  • And in the line #define ACTUATOR_PIN 4 (is the next line): replace 4 for 2 (this because I connected the
    led to pin 2, if you wish change it)
  • Now connect your circuit (as it says in step 4 of the comment block)
  • Compile and upload
  • In the dashboard again: click in add actuator
  • Try it now
oooh thank you. It works.
