I changed the order the digital output appeared in my ‘App Payload’ on the embedded device, and the error “problem sending command: Wrong Senet API Key” no longer appears. Not sure if that mattered or if something on the Cayenne side changed.
Now, when I use the Cayenne “Digital output” control in a project, it ends up sending an App Payload of 0x000064FF to the Senet network (and my device). I can see this value appear in my embedded device LoRaRx memory buffer. This doesn’t seem like it matches anything in the Cayenne LPP format.
If I send a downlink PDU message from the Senet site that matches the Cayenne LPP format, I’ll see my LoRaRx buffer update as expected. Same result for when I use the Curl POST method described here: http://docs.senetco.io/docs/dev/#downlink-api
I’m tagging @eptak here as well as I suspect he’s best positioned to answer this question about what the format of an LPP downlink payload should look like.
My understanding is that a digital actuator payload coming IN (so uplink) to Cayenne via LPP should look like this (using an example of channel 5):
However, I’m not sure what it looks like going in the other (downlink) direction, which is I think where he can help. Thanks for your patience, I think we can both learn something here
