Problem sending Values
Hello guys, my program is not sending codes, sometimes it sends annoying codes and in most of times it doesn’t send…
The code is:
Temperatura();
void Temperatura()
float h = dht.readHumidity();
float temp = dht.readTemperature();
float hic = dht.computeHeatIndex(temp, h, false);
myNextion.setComponentText(“t0”, String(temp));
myNextion.setComponentText(“t2”, String(h));
delay(2000);
Cayenne.virtualWrite(V0,temp);
I also tried:
CAYENNE_OUT(V0)
delay(2000);
And also tried:
Cayenne.run(); // (CAYENNE)
None of them sent any command, the virtual pin is correct (in that case 0), I checked the sensor in Cayenne and it’s ok… The problem probably is the code, but I don’t know what I’m doing wrong…
Cayenne is connecting normally…
Hi
Try it this way.
   include ......
    float h;
    float temp;
    float hic;
    Temperatura();
    void Temperatura()
    myNextion.setComponentText("t0", String(temp));
    myNextion.setComponentText("t2", String(h));
    delay(2000);
    CAYENNE_OUT(V0)
It doesn’t work :frowning:
Are you getting any errors in the serial monitor?
