Problem while adding Sensor
Respected,
i am succesfully connected arduino Uno using serial communication.
now i want to add motion sensor with ardiuno.
but when i select add new sensor and upload sketch my connection gone offline so plz guide me.
can you share the code.
char username[] = "";
char password[] = "";
char clientID[] = "";
#define SENSOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL 1
  checkSensor();
int previousState = -1;
int currentState = -1;
void checkSensor()
  if (currentMillis - previousMillis >= 250) {
    currentState = digitalRead(SENSOR_PIN);
      Cayenne.virtualWrite(VIRTUAL_CHANNEL 1, currentState);
      previousState = currentState;
what kind of connection are you using.
Serial usb connection
you have to modify the same code you used to connect.
ok i will try it.
