Problem with adding actuator
Hi, I’m using Ethernet shield in my project to control the speed of DC motor. I tried to creat actuator, but shows pop up message like “can not connect with remote device”… please help soon as possible… :frowning: Screenshot_20180209_164820|281x500
can you post the code.
Thank you I solved it, and I had a small doubt. How to send a mapped value to dashboard from Arduino ??
use “Cayenne.virtualWrite(1, x);” where x is your value.
#include <PID_v1.h>
#define PIN_INPUT 0
#define PIN_OUTPUT 3
double Setpoint, Input, Output;
double aggKp = 4, aggKi = 0.2, aggKd = 1;
double consKp = 1, consKi = 0.05, consKd = 0.25;
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
Input = analogRead(PIN_INPUT);
Setpoint = 100;
myPID.SetMode(AUTOMATIC);
double gap = abs(Setpoint - Input);
if (gap < 10)
myPID.SetTunings(consKp, consKi, consKd);
else
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
analogWrite(PIN_OUTPUT, Output);
This is my program. I want to change setpoint through internet and monitor the Input value in dashboard. So what are changes i want to do. I’m using Arduino Ethernet Shield.
add a custom slider widget and read the status.
CAYENNE_IN(1)
  setpoint = getValue.asInt();
	lastMillis = millis();
	Cayenne.virtualWrite(0, Input);
this will add a value widget to your dashboard automatically.
Thank you so much :slight_smile:
