According to your output there you should be good to go. Is your Pi showing as online now?
That looks like the end of a successful install!
Once the Pi is back from reboot, check your Cayenne web dashboard and see if it is listed and showing as online.
Which command to start now?
YES !!!
Thank you VERY MUCH !!!
Yes, in the bottom-right there should be a red ‘Remove’ button
THANK YOU for help, rsiegel !!!
The problem is resolved.
My Cayene work !!!
Best regards,
Oleg.
Thanks for your patience! Hopefully when you add another device it will go more smoothly. Feel free to make a new thread if you have questions or problems with Cayenne in the future
I got the same problem and solved it by editing the .sh file…
Replace the https with http
