Problems next raspberry pi
Trying to connect a second raspberry pi and get the following message:
Error getting invite code!
Please help!!!
Hi @c.stouten77,
When running the commands to install the Cayenne agent on your Pi, did you generate a new link from Add New > Device/Widget > Single Board Computers > Raspberry Pi? I think if you try to re-use an old link you might get this issue.
If that’s the case, could you share the terminal output from when trying to install, so I can see the context around the error message?
I have figured out the problem
i have reinstalled the software on my tablet
thanks for te help
