Proof of concept door alarm
About This Project
First project using the Android App. A proof of concept of an alarm than notifies me via email when a door is opened. Still needs to be set up to be battery powered but the concept works.
The capacitive touch sensor is attached to digital pin 2 of the arduino and Cayenne reads that input and inverts it. When the door is closed the magnet is near enough to the capacitive touch sensor to give a logic high level. This is inverted by cayenne so while the door is closed, cayenne outputs a 1. When the door is opened, the magnet moves away from the sensor, the capacitive touch sensor outputs a 0, so cayenne outputs a 1 and triggers the notification.
What’s Connected
Cayenne, Arduino Uno, Ethernet Shield W5100, TTP223B capacitive touch sensor, magnet, sticky tape, jumper wires, breadboard.
Triggers & Alerts
When door is open (cayenne output is 1), send email notification.
Dashboard Screenshots
Photos of the Project
@one21two12
can you provide me the code for TTP223 Based Capacitive Touch Sensor Module?? i am not able to interface
