None
patrick@raspberrypi:~ $ sudo -H python3 -m myDevices -P /var/run/myDevices.pid
File "/usr/lib/python3.4/runpy.py", line 170, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.4/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.4/dist-packages/myDevices-0.1.20741-py3.4.egg/myDevices/__main__.py", line 3, in <module>
from myDevices.cloud.client import CloudServerClient
File "/usr/local/lib/python3.4/dist-packages/myDevices-0.1.20741-py3.4.egg/myDevices/cloud/client.py", line 13, in <module>
from myDevices.remoteaccess import RemoteDesktop
File "/usr/local/lib/python3.4/dist-packages/myDevices-0.1.20741-py3.4.egg/myDevices/remoteaccess/__init__.py", line 6, in <module>
from myDevices.os.services import ServiceManager
File "/usr/local/lib/python3.4/dist-packages/myDevices-0.1.20741-py3.4.egg/myDevices/os/services.py", line 4, in <module>
from psutil import Process, get_pid_list, phymem_usage, cpu_percent
ImportError: cannot import name 'get_pid_list'
