Python build failed when trying to install Cayenne
Thank you for taking the time to submit your bug/issue! Please use the points below as a guide when submitting.
Device: Rasberrypi zero w
Dashboard: Web, Putty for ssh
./myDevices-1.0/
./myDevices-1.0/._.DS_Store
./myDevices-1.0/.DS_Store
./myDevices-1.0/3rd_party/
./myDevices-1.0/addCron.sh
./myDevices-1.0/ca.crt
./myDevices-1.0/crontab.sh
./myDevices-1.0/deb/
./myDevices-1.0/dev_network.ini
./myDevices-1.0/libs/
./myDevices-1.0/live_network.ini
./myDevices-1.0/package
./myDevices-1.0/preprod_network.ini
./myDevices-1.0/python/
./myDevices-1.0/qa1_network.ini
./myDevices-1.0/qa2_network.ini
./myDevices-1.0/reboot_install.sh
./myDevices-1.0/scripts/
./myDevices-1.0/setup.sh
./myDevices-1.0/stg_network.ini
./myDevices-1.0/uninstall.sh
./myDevices-1.0/scripts/config.sh
./myDevices-1.0/scripts/tightvncsetup.sh
./myDevices-1.0/scripts/webiopisetup.sh
./myDevices-1.0/python/myDevices/
./myDevices-1.0/python/myDevices.init.sh
./myDevices-1.0/python/myDevices.service
./myDevices-1.0/python/myDevices.sh
./myDevices-1.0/python/setup.py
./myDevices-1.0/python/myDevices/init.py
./myDevices-1.0/python/myDevices/main.py
./myDevices-1.0/python/myDevices/cloud/
./myDevices-1.0/python/myDevices/ipgetter/
./myDevices-1.0/python/myDevices/os/
./myDevices-1.0/python/myDevices/remoteaccess/
./myDevices-1.0/python/myDevices/requests_futures/
./myDevices-1.0/python/myDevices/schedule/
./myDevices-1.0/python/myDevices/sensors/
./myDevices-1.0/python/myDevices/test/
./myDevices-1.0/python/myDevices/utils/
./myDevices-1.0/python/myDevices/wifi/
./myDevices-1.0/python/myDevices/wifi/init.py
./myDevices-1.0/python/myDevices/wifi/WifiManager.py
./myDevices-1.0/python/myDevices/wifi/wifisetup.py
./myDevices-1.0/python/myDevices/wifi/WirelessLib.py
./myDevices-1.0/python/myDevices/utils/init.py
./myDevices-1.0/python/myDevices/utils/config.py
./myDevices-1.0/python/myDevices/utils/crypto.py
./myDevices-1.0/python/myDevices/utils/history.py
./myDevices-1.0/python/myDevices/utils/logger.py
./myDevices-1.0/python/myDevices/utils/mutex.py
./myDevices-1.0/python/myDevices/utils/singleton.py
./myDevices-1.0/python/myDevices/test/all_tests.py
./myDevices-1.0/python/myDevices/test/cloud_test.py
./myDevices-1.0/python/myDevices/test/config_test.py
./myDevices-1.0/python/myDevices/test/history_test.py
./myDevices-1.0/python/myDevices/test/remoteaccess_test.py
./myDevices-1.0/python/myDevices/test/scheduler_test.py
./myDevices-1.0/python/myDevices/test/sensors_test.py
./myDevices-1.0/python/myDevices/test/updater_test.py
./myDevices-1.0/python/myDevices/sensors/init.py
./myDevices-1.0/python/myDevices/sensors/client.py
./myDevices-1.0/python/myDevices/sensors/sensors.py
./myDevices-1.0/python/myDevices/schedule/init.py
./myDevices-1.0/python/myDevices/requests_futures/init.py
./myDevices-1.0/python/myDevices/requests_futures/sessions.py
./myDevices-1.0/python/myDevices/remoteaccess/init.py
./myDevices-1.0/python/myDevices/os/init.py
./myDevices-1.0/python/myDevices/os/cpu.py
./myDevices-1.0/python/myDevices/os/daemon.py
./myDevices-1.0/python/myDevices/os/getsysteminfo.py
./myDevices-1.0/python/myDevices/os/raspiconfig.py
./myDevices-1.0/python/myDevices/os/services.py
./myDevices-1.0/python/myDevices/os/systeminfo.py
./myDevices-1.0/python/myDevices/os/threadpool.py
./myDevices-1.0/python/myDevices/ipgetter/init.py
./myDevices-1.0/python/myDevices/cloud/init.py
./myDevices-1.0/python/myDevices/cloud/actions.py
./myDevices-1.0/python/myDevices/cloud/cayenneclient.py
./myDevices-1.0/python/myDevices/cloud/client.py
./myDevices-1.0/python/myDevices/cloud/dbmanager.py
./myDevices-1.0/python/myDevices/cloud/download_speed.py
./myDevices-1.0/python/myDevices/cloud/installer.py
./myDevices-1.0/python/myDevices/cloud/scheduler.py
./myDevices-1.0/python/myDevices/cloud/trigger.py
./myDevices-1.0/python/myDevices/cloud/updater.py
./myDevices-1.0/python/myDevices/cloud/vcom_id.py
./myDevices-1.0/libs/libSystemInformation.so
./myDevices-1.0/deb/debian_dependencies.txt
./myDevices-1.0/deb/download.sh
./myDevices-1.0/deb/install
./myDevices-1.0/deb/install_packages.sh
./myDevices-1.0/deb/libiw-dev/
./myDevices-1.0/deb/package
./myDevices-1.0/deb/python3-setuptools/
./myDevices-1.0/deb/tightvncserver/
./myDevices-1.0/deb/tightvncserver/expect_5.45-2_armhf.deb
./myDevices-1.0/deb/tightvncserver/install
./myDevices-1.0/deb/tightvncserver/libjpeg62-turbo_1.4.1-2_armhf.deb
./myDevices-1.0/deb/tightvncserver/tightvncserver_1.3.9-6.6_armhf.deb
./myDevices-1.0/deb/tightvncserver/xfonts-base_1.0.4+nmu1_all.deb
./myDevices-1.0/deb/python3-setuptools/install
./myDevices-1.0/deb/python3-setuptools/python3-pkg-resources_0.6.24-1_all.deb
./myDevices-1.0/deb/python3-setuptools/python3-setuptools_0.6.24-1_all.deb
./myDevices-1.0/deb/libiw-dev/install
./myDevices-1.0/deb/libiw-dev/libiw-dev_30~pre9-8_armhf.deb
./myDevices-1.0/3rd_party/enum34-1.0.4.tar.gz
./myDevices-1.0/3rd_party/install
./myDevices-1.0/3rd_party/install_packages.sh
./myDevices-1.0/3rd_party/iwlib-1.5.tar.gz
./myDevices-1.0/3rd_party/jsonpickle-0.9.2.tar.gz
./myDevices-1.0/3rd_party/netifaces-0.10.4.tar.gz
./myDevices-1.0/3rd_party/package
./myDevices-1.0/3rd_party/psutil-0.6.0.tar.gz
./myDevices-1.0/3rd_party/requests.tar.gz
./myDevices-1.0/3rd_party/suds-jurko-0.6.tar.gz
  • set -x
  • exec
    (0%)
    Sat 1 Jul 17:43:13 UTC 2017 Installing myDevices agent
    Sat 1 Jul 17:43:43 UTC 2017 Found Python 3.4.2…
    (50%)
    Sat 1 Jul 17:43:43 UTC 2017 Copying agent libraries
    (55%)
    Sat 1 Jul 17:44:30 UTC 2017 Installing python utils
    (60%)
    Sat 1 Jul 17:44:39 UTC 2017 Installing software components
    Sat 1 Jul 17:44:40 UTC 2017 Trying to install myDevices for python3 version: Python 3.4.2
    Sat 1 Jul 17:44:41 UTC 2017 Build for Python 3.4.2 failed\n
When I use the commands suggested to try and fix the issue, none of them have worked and tell me to use “sudo apt-get -f install” to fix it, once I run those it says that it is unable to correct dependencies.
