Raspbarry dht sensor dashboard
hi, I would like to be able to insert a dht sensor in racks with raspbarry, but I noticed that if I use l mqtt do not work the triggers, so I wanted to embend with cayenne, who helps me?
help me
Hey @Massimotruglio83 sorry for the delay. There is a bug with triggers right now. If you delete your device from the dashboard and generate a new one (and connect with those credentials) you can recreate the triggers and they should work. Just take care not to delete any widgets.
