Raspberry & arduino Due by serial
after the update I’m getting crazy, the inputs do not work and only some outputs.
the arduino is connected but something is wrong, and correct the program?
char username[] = "";
char password[] = "";
char clientID[] = "";
//************* Action pins Out 1°piano rele N.O.************************
#define VIRTUAL_CHANNEL22 22
#define VIRTUAL_CHANNEL24 24
#define VIRTUAL_CHANNEL26 26
#define VIRTUAL_CHANNEL28 28
#define VIRTUAL_CHANNEL30 30
#define VIRTUAL_CHANNEL32 32
#define VIRTUAL_CHANNEL34 34
#define VIRTUAL_CHANNEL36 36
#define VIRTUAL_CHANNEL38 38
#define VIRTUAL_CHANNEL40 40
#define VIRTUAL_CHANNEL42 42
#define VIRTUAL_CHANNEL44 44
#define VIRTUAL_CHANNEL46 46
#define VIRTUAL_CHANNEL48 48
#define VIRTUAL_CHANNEL50 50
#define VIRTUAL_CHANNEL52 52
#define ACTUATOR_PIN22 22
#define ACTUATOR_PIN24 24
#define ACTUATOR_PIN26 26
#define ACTUATOR_PIN28 28
#define ACTUATOR_PIN30 30
#define ACTUATOR_PIN32 32
#define ACTUATOR_PIN34 34
#define ACTUATOR_PIN36 36
#define ACTUATOR_PIN38 38
#define ACTUATOR_PIN40 40
#define ACTUATOR_PIN42 42
#define ACTUATOR_PIN44 44
#define ACTUATOR_PIN46 46
#define ACTUATOR_PIN48 48
#define ACTUATOR_PIN50 50
#define ACTUATOR_PIN52 52
//*************Action pins Input gnd  2°piano************************************
#define VIRTUAL_CHANNEL2 2
#define VIRTUAL_CHANNEL3 3
#define VIRTUAL_CHANNEL4 4
#define VIRTUAL_CHANNEL5 5
#define VIRTUAL_CHANNEL6 6
#define VIRTUAL_CHANNEL7 7
#define VIRTUAL_CHANNEL8 8
#define VIRTUAL_CHANNEL9 9
#define VIRTUAL_CHANNEL10 10
#define VIRTUAL_CHANNEL11 11
#define VIRTUAL_CHANNEL12 12
#define VIRTUAL_CHANNEL13 13
#define VIRTUAL_CHANNEL14 14
#define VIRTUAL_CHANNEL15 15
#define VIRTUAL_CHANNEL16 16
#define VIRTUAL_CHANNEL17 17
#define SENSOR_PIN2 2
#define SENSOR_PIN3 3
#define SENSOR_PIN4 4
#define SENSOR_PIN5 5
#define SENSOR_PIN6 6
#define SENSOR_PIN7 7
#define SENSOR_PIN8 8
#define SENSOR_PIN9 9
#define SENSOR_PIN10 10
#define SENSOR_PIN11 11
#define SENSOR_PIN12 12
#define SENSOR_PIN13 13
#define SENSOR_PIN14 14
#define SENSOR_PIN15 15
#define SENSOR_PIN16 16
#define SENSOR_PIN17 17
//*************Action pins Input +  2°piano************************************
#define VIRTUAL_CHANNEL23 23
#define VIRTUAL_CHANNEL25 25
#define VIRTUAL_CHANNEL27 27
#define VIRTUAL_CHANNEL29 29
#define VIRTUAL_CHANNEL31 31
#define VIRTUAL_CHANNEL33 33
#define VIRTUAL_CHANNEL35 35
#define VIRTUAL_CHANNEL37 37
#define VIRTUAL_CHANNEL39 39
#define VIRTUAL_CHANNEL41 41
#define VIRTUAL_CHANNEL43 43
#define VIRTUAL_CHANNEL45 45
#define VIRTUAL_CHANNEL47 47
#define VIRTUAL_CHANNEL49 49
#define VIRTUAL_CHANNEL51 51
#define VIRTUAL_CHANNEL53 53
#define SENSOR_PIN23 23
#define SENSOR_PIN25 25
#define SENSOR_PIN27 27
#define SENSOR_PIN29 29
#define SENSOR_PIN31 31
#define SENSOR_PIN33 33
#define SENSOR_PIN35 35
#define SENSOR_PIN37 37
#define SENSOR_PIN39 39
#define SENSOR_PIN41 41
#define SENSOR_PIN43 43
#define SENSOR_PIN45 45
#define SENSOR_PIN47 47
#define SENSOR_PIN49 49
#define SENSOR_PIN51 51
#define SENSOR_PIN53 53
  //Serial.begin(9600);
  //Baud rate can be specified by calling Cayenne.begin(username, password, clientID, 9600);
pinMode (ACTUATOR_PIN22, OUTPUT);
pinMode (ACTUATOR_PIN24, OUTPUT);
pinMode (ACTUATOR_PIN26, OUTPUT);
pinMode (ACTUATOR_PIN28, OUTPUT);
pinMode (ACTUATOR_PIN30, OUTPUT);
pinMode (ACTUATOR_PIN32, OUTPUT);
pinMode (ACTUATOR_PIN34, OUTPUT);
pinMode (ACTUATOR_PIN36, OUTPUT);
pinMode (ACTUATOR_PIN38, OUTPUT);
pinMode (ACTUATOR_PIN40, OUTPUT);
pinMode (ACTUATOR_PIN42, OUTPUT);
pinMode (ACTUATOR_PIN44, OUTPUT);
pinMode (ACTUATOR_PIN46, OUTPUT);
pinMode (ACTUATOR_PIN48, OUTPUT);
pinMode (ACTUATOR_PIN50, OUTPUT);
pinMode (ACTUATOR_PIN52, OUTPUT);
pinMode (SENSOR_PIN2 , INPUT_PULLUP);
pinMode (SENSOR_PIN3 , INPUT_PULLUP);
pinMode (SENSOR_PIN4 , INPUT_PULLUP);
pinMode (SENSOR_PIN5 , INPUT_PULLUP);
pinMode (SENSOR_PIN6 , INPUT_PULLUP);
pinMode (SENSOR_PIN7 , INPUT_PULLUP);
pinMode (SENSOR_PIN8 , INPUT_PULLUP);
pinMode (SENSOR_PIN9 , INPUT_PULLUP);
pinMode (SENSOR_PIN10 , INPUT_PULLUP);
pinMode (SENSOR_PIN11 , INPUT_PULLUP);
pinMode (SENSOR_PIN12 , INPUT_PULLUP);
pinMode (SENSOR_PIN13 , INPUT_PULLUP);
pinMode (SENSOR_PIN14 , INPUT_PULLUP);
pinMode (SENSOR_PIN15 , INPUT_PULLUP);
pinMode (SENSOR_PIN16 , INPUT_PULLUP);
pinMode (SENSOR_PIN17 , INPUT_PULLUP);
pinMode (SENSOR_PIN23, INPUT);
pinMode (SENSOR_PIN25, INPUT_PULLUP);
pinMode (SENSOR_PIN27, INPUT);
pinMode (SENSOR_PIN29, INPUT);
pinMode (SENSOR_PIN31, INPUT);
pinMode (SENSOR_PIN33, INPUT);
pinMode (SENSOR_PIN35, INPUT);
pinMode (SENSOR_PIN37, INPUT);
pinMode (SENSOR_PIN39, INPUT);
pinMode (SENSOR_PIN41, INPUT);
pinMode (SENSOR_PIN43, INPUT);
pinMode (SENSOR_PIN45, INPUT);
pinMode (SENSOR_PIN47, INPUT);
pinMode (SENSOR_PIN49, INPUT);
pinMode (SENSOR_PIN51, INPUT);
pinMode (SENSOR_PIN53, INPUT);
//  uscite valide ***********************************************************************************
CAYENNE_IN(VIRTUAL_CHANNEL22)
{int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN22, HIGH);}
  else { digitalWrite(ACTUATOR_PIN22, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL24)
{int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN24, HIGH);}
  else { digitalWrite(ACTUATOR_PIN24, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL26)
{int value = getValue.asInt();   if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN26, HIGH);}
  else { digitalWrite(ACTUATOR_PIN26, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL28)
{int value = getValue.asInt();   if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN28, HIGH);}
  else { digitalWrite(ACTUATOR_PIN28, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL30)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN30, HIGH);}
  else { digitalWrite(ACTUATOR_PIN30, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL32)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN32, HIGH);}
  else { digitalWrite(ACTUATOR_PIN32, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL34)
{int value = getValue.asInt();   if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN34, HIGH);}
  else { digitalWrite(ACTUATOR_PIN34, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL36)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN36, HIGH);}
  else { digitalWrite(ACTUATOR_PIN36, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL38)
{int value = getValue.asInt();   if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN38, HIGH);}
  else { digitalWrite(ACTUATOR_PIN38, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL40)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN40, HIGH);}
  else { digitalWrite(ACTUATOR_PIN40, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL42)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN42, HIGH);}
  else { digitalWrite(ACTUATOR_PIN42, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL44)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN44, HIGH);}
  else { digitalWrite(ACTUATOR_PIN44, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL46)
{int value = getValue.asInt();   if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN46, HIGH);}
  else { digitalWrite(ACTUATOR_PIN46, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL48)
{int value = getValue.asInt();   if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN48, HIGH);}
  else { digitalWrite(ACTUATOR_PIN48, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL50)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN50, HIGH);}
  else { digitalWrite(ACTUATOR_PIN50, LOW);}}
CAYENNE_IN(VIRTUAL_CHANNEL52)
{ int value = getValue.asInt();  if (getValue.asInt() == 1) { digitalWrite(ACTUATOR_PIN52, HIGH);}
  else { digitalWrite(ACTUATOR_PIN52, LOW);}}
//    Ingressi    ********************************************************************
CAYENNE_OUT(VIRTUAL_CHANNEL2)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL2, digitalRead(SENSOR_PIN2));}
CAYENNE_OUT(VIRTUAL_CHANNEL3)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL3, digitalRead(SENSOR_PIN3));}
CAYENNE_OUT(VIRTUAL_CHANNEL4)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL4, digitalRead(SENSOR_PIN4));}
CAYENNE_OUT(VIRTUAL_CHANNEL5)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL5, digitalRead(SENSOR_PIN5));}
CAYENNE_OUT(VIRTUAL_CHANNEL6)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL6, digitalRead(SENSOR_PIN6));}
CAYENNE_OUT(VIRTUAL_CHANNEL7)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL7, digitalRead(SENSOR_PIN7));}
CAYENNE_OUT(VIRTUAL_CHANNEL8)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL8, digitalRead(SENSOR_PIN8));}
CAYENNE_OUT(VIRTUAL_CHANNEL9)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL9, digitalRead(SENSOR_PIN9));}
CAYENNE_OUT(VIRTUAL_CHANNEL10)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL10, digitalRead(SENSOR_PIN10));}
CAYENNE_OUT(VIRTUAL_CHANNEL11)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL11, digitalRead(SENSOR_PIN11));}
CAYENNE_OUT(VIRTUAL_CHANNEL12)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL12, digitalRead(SENSOR_PIN12));}
CAYENNE_OUT(VIRTUAL_CHANNEL13)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL13, digitalRead(SENSOR_PIN13));}
CAYENNE_OUT(VIRTUAL_CHANNEL14)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL14, digitalRead(SENSOR_PIN14));}
CAYENNE_OUT(VIRTUAL_CHANNEL15)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL15, digitalRead(SENSOR_PIN15));}
CAYENNE_OUT(VIRTUAL_CHANNEL16)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL16, digitalRead(SENSOR_PIN16));}
CAYENNE_OUT(VIRTUAL_CHANNEL17)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL17, digitalRead(SENSOR_PIN17));}
CAYENNE_OUT(VIRTUAL_CHANNEL23)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL23, digitalRead(SENSOR_PIN23));}
CAYENNE_OUT(VIRTUAL_CHANNEL25)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL25, digitalRead(SENSOR_PIN25));}
CAYENNE_OUT(VIRTUAL_CHANNEL27)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL27, digitalRead(SENSOR_PIN27));}
CAYENNE_OUT(VIRTUAL_CHANNEL29)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL29, digitalRead(SENSOR_PIN29));}
CAYENNE_OUT(VIRTUAL_CHANNEL31)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL31, digitalRead(SENSOR_PIN31));}
CAYENNE_OUT(VIRTUAL_CHANNEL33)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL33, digitalRead(SENSOR_PIN33));}
CAYENNE_OUT(VIRTUAL_CHANNEL35)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL35, digitalRead(SENSOR_PIN35));}
CAYENNE_OUT(VIRTUAL_CHANNEL37)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL37, digitalRead(SENSOR_PIN37));}
CAYENNE_OUT(VIRTUAL_CHANNEL39)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL39, digitalRead(SENSOR_PIN39));}
CAYENNE_OUT(VIRTUAL_CHANNEL41)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL41, digitalRead(SENSOR_PIN41));}
CAYENNE_OUT(VIRTUAL_CHANNEL43)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL43, digitalRead(SENSOR_PIN43));}
CAYENNE_OUT(VIRTUAL_CHANNEL45)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL45, digitalRead(SENSOR_PIN45));}
CAYENNE_OUT(VIRTUAL_CHANNEL47)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL47, digitalRead(SENSOR_PIN47));}
CAYENNE_OUT(VIRTUAL_CHANNEL49)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL49, digitalRead(SENSOR_PIN49));}
CAYENNE_OUT(VIRTUAL_CHANNEL51)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL51, digitalRead(SENSOR_PIN51));}
CAYENNE_OUT(VIRTUAL_CHANNEL53)
{Cayenne.virtualWrite(VIRTUAL_CHANNEL53, digitalRead(SENSOR_PIN53));}
do you have any other way to connect your device to cayenne like an ethernet shield or esp8266? As CayenneMQTTSerial library is a bit difficult as you cannot find the cause of the error using debugging.
I have updated the system with W5100 ethernet.
ok connect, but outputs 32 to 52 do not work
inputs still to be tested
how do I insert the listing in the below window?
#define CAYENNE_DEBUG       // Uncomment to show debug messages
//************* Action pins Out 1°floor relè N.O.************************
//*************Action pins Input gnd  2° floor ************************************
//#define VIRTUAL_CHANNEL10 10  // disable for w5100
//#define SENSOR_PIN10 10  // disable for w5100
//*************Action pins Input +  2° floor ************************************
//pinMode (SENSOR_PIN10 , INPUT_PULLUP);  // disable for w5100
//  Output Do ***********************************************************************************
{CAYENNE_LOG("Channel %u, value %s", request.channel, getValue.asString());
int currentValue22 = getValue.asInt(); if (currentValue22 == 1) { digitalWrite(ACTUATOR_PIN22, HIGH);}
int currentValue24 = getValue.asInt(); if (currentValue24 == 1) { digitalWrite(ACTUATOR_PIN24, HIGH);}
int currentValue26 = getValue.asInt(); if (currentValue26 == 1)  { digitalWrite(ACTUATOR_PIN26, HIGH);}
int currentValue28 = getValue.asInt(); if (currentValue28 == 1)  { digitalWrite(ACTUATOR_PIN28, HIGH);}
int currentValue30 = getValue.asInt(); if (currentValue30 == 1) { digitalWrite(ACTUATOR_PIN30, HIGH);}
int currentValue32 = getValue.asInt(); if (currentValue32 == 1) { digitalWrite(ACTUATOR_PIN32, HIGH);}
int currentValue34 = getValue.asInt(); if (currentValue34 == 1)  { digitalWrite(ACTUATOR_PIN34, HIGH);}
int currentValue36 = getValue.asInt(); if (currentValue36 == 1) { digitalWrite(ACTUATOR_PIN36, HIGH);}
int currentValue38 = getValue.asInt(); if (currentValue38 == 1)  { digitalWrite(ACTUATOR_PIN38, HIGH);}
int currentValue40 = getValue.asInt(); if (currentValue40 == 1) { digitalWrite(ACTUATOR_PIN40, HIGH);}
int currentValue42 = getValue.asInt(); if (currentValue42 == 1) { digitalWrite(ACTUATOR_PIN42, HIGH);}
int currentValue44 = getValue.asInt(); if (currentValue44 == 1) { digitalWrite(ACTUATOR_PIN44, HIGH);}
int currentValue46 = getValue.asInt(); if (currentValue46 == 1)  { digitalWrite(ACTUATOR_PIN46, HIGH);}
int currentValue48 = getValue.asInt(); if (currentValue48 == 1)  { digitalWrite(ACTUATOR_PIN48, HIGH);}
int currentValue50 = getValue.asInt(); if (currentValue50 == 1) { digitalWrite(ACTUATOR_PIN50, HIGH);}
int currentValue52 = getValue.asInt(); if (currentValue52 == 1) { digitalWrite(ACTUATOR_PIN52, HIGH);}
//    reading Input    ********************************************************************
//CAYENNE_OUT(VIRTUAL_CHANNEL10)
//{Cayenne.virtualWrite(VIRTUAL_CHANNEL10, digitalRead(SENSOR_PIN10));}
for channel greater than 30 you have to use CAYENNE_OUT_DEFAULT() and CAYENNE_IN_DEFAULT().
for receiving data:
CAYENNE_LOG("CAYENNE_IN_DEFAULT(%u) - %s, %u", request.channel, getValue.getId(),
    getValue.asInt());
    switch (request.channel) {
 case 32 :
   int x = getValue.asInt();
   Serial.println(x);
   break;
 case 33 :
   Serial.println(x);
   break;
and for sending data:
   Cayenne.virtualWrite(34, millis());
   Cayenne.virtualWrite(35, digitalRead(SENSOR_PIN35));
Thank you,
this works perfectly
CAYENNE_LOG(“CAYENNE_IN_DEFAULT(%u) - %s, %u”, request.channel, getValue.getId(),
getValue.asInt());
case 32 :
Serial.println(x); // for debug
if (x == 1) { digitalWrite(ACTUATOR_PIN32, HIGH);}
break;
If I put two cases gives me error
getValue.asInt());
case 32 :
break;
case 34 :
if (x == 1) { digitalWrite(ACTUATOR_PIN34, HIGH);}
break;
give me this error:
arduinodue_w5100_eth_ok:189:8: error: ‘int x’ previously declared here
exit status 1
jump to case label [-fpermissive]
change to:
case 34 :
int y = getValue.asInt();
Serial.println(y); // for debug
if (y == 1) { digitalWrite(ACTUATOR_PIN34, HIGH);}
break;
no work
getValue.asInt());
case 32 :
break;
case 34 :
break;
same error :
arduinodue_w5100_eth_ok:189:8: error: crosses initialization of ‘int x’
exit status 1
can you post the entire code.
    getValue.asInt());
 case 32 :
  break;
  case 34 :
   break;
/*  Disable for test
CAYENNE_IN(34)
{if (getValue.asInt() == 1) {digitalWrite(ACTUATOR_PIN34, HIGH);}
else {digitalWrite(ACTUATOR_PIN34, LOW);}}
give this a try:
int x;
int y;
  CAYENNE_LOG("CAYENNE_IN_DEFAULT(%u) - %s, %u", request.channel, getValue.getId(), getValue.asInt());
    case 31 :
      Serial.println(x);
      if (x == 1) {
      else {
      break;
    case 32 :
      Serial.println(y);
      if (y == 1) {
      else {
      break;
{ CAYENNE_LOG("Channel %u, value %s", request.channel, getValue.asString());
  else {
  else {
  else {
  else {
  else {
/*  Disable for test
  CAYENNE_IN(34)
thanks now it works.
I can change x and y in:
int x32;
int x34;
CAYENNE_LOG(“CAYENNE_IN_DEFAULT(%u) - %s, %u”, request.channel, getValue.getId(), getValue.asInt());
case 32 :
x32 = getValue.asInt();
Serial.println(x32);
if (x32 == 1) {
else {
break;
case 34 :
x34 = getValue.asInt();
Serial.println(x34);
if (x34 == 1) {
else {
break;
to avoid confusion by associating the variables with the output addresses?
