Raspberry Pi 3 with Windows 10 IOT as OS
I started to play with Raspberry Pi 3 with Windows 10 IOT Core OS and programming with VS, particularly in Visual Basic UWP.
I’m going to be blunt. Will Cayenne work on this setup?
hi @fred2013ies official cayenne does not support it but see if you can implement something using MQTT library.
Thanks for your comment. May I ask you to do one thing. Review this article and share it with others if need be. Would this then be the solution to use Win 10 IOT with Cayenne?
yes. i will pass this to the developer team.
