I’ve just set up my first device a Raspberry Pi 3. But it is showing as Offline. I’ve followed Adam’s “Troubleshooting Pi Showing Up as Offline in Dashboard” post 7 June 2016. Below are the outputs from the commands:
From command prompt on my PC:
arp -a
IP 10.1.1.9 MAC b8-27-eb-4a-…
From Putty connected to Pi:
df- h
Filesystem Size Used Avail Use% Mounted on
/dev/root 14G 3.9G 8.6G 32% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 6.4M 456M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 462M 0 462M 0% /sys/fs/cgroup
/dev/mmcblk0p6 65M 21M 45M 33% /boot
tmpfs 93M 0 93M 0% /run/user/0
tmpfs 93M 0 93M 0% /run/user/1000
/dev/mmcblk0p5 30M 1.6M 27M 6% /media/pi/SETTINGS1
ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:1f:82:80 brd ff:ff:ff:ff:ff:ff
inet6 fe80::55ae:2f36:8c97:4b72/64 scope link tentative
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:4a:d7:d5 brd ff:ff:ff:ff:ff:ff
inet 10.1.1.9/24 brd 10.1.1.255 scope global wlan0
inet6 fdcc:a223:4673:6400:2d:aaf1:a616:9da3/64 scope global noprefixroute dynamic
valid_lft 7117sec preferred_lft 3517sec
inet6 fe80::5c06:45be:12b8:82c6/64 scope link
nslookup cloud.mydevices.com
-bash nslookup: command not found
(from command prompt on PC Name: cloud.medevices.com Addresses: 54.173.248.213 & 34.199.178.126)
ping google.com
PING google.com (216.58.196.142) 56(84) bytes of data.
64 bytes from syd15s04-in-f14.1e100.net (216.58.196.142): icmp_seq=1 ttl=53 time=32.4 ms
sudo netstat -natp | grep -i established
tcp 0 0 10.1.1.9:55954 54.173.248.213:8181 ESTABLISHED 530/python3
sudo apt-get install telnet
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt-get -f install’ to correct these:
The following packages have unmet dependencies:
expect : Depends: tcl8.5 (>= 8.5.0) but it is not going to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
(telnet from PC appears to connect)
sudo service myDevices status
● myDevices.service - myDevices service
Loaded: loaded (/etc/systemd/system/myDevices.service; enabled)
Active: active (running) since Mon 2017-08-28 15:53:16 NZST; 52min ago
Main PID: 530 (python3)
CGroup: /system.slice/myDevices.service
‣ 530 /usr/bin/python3 -m myDevices -P /var/run/myDevices.pid
Aug 28 15:53:16 pi2 systemd[1]: Starting myDevices service…
Aug 28 15:53:16 pi2 systemd[1]: Started myDevices service.
Aug 28 15:53:17 pi2 systemd[530]: pam_exec(login:session): conversation failed
Aug 28 15:53:17 pi2 systemd[530]: pam_unix(login:session): session opened for user root by (uid=0)
sudo service webiopi status
● webiopi.service - LSB: WebIOPi initscript
Loaded: loaded (/etc/init.d/webiopi)
Active: active (running) since Mon 2017-08-28 15:53:16 NZST; 53min ago
Process: 555 ExecStart=/etc/init.d/webiopi start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/webiopi.service
└─580 /usr/bin/python3 -m webiopi -l /var/log/webiopi -c /etc/webiopi/config
Aug 28 15:53:16 pi2 systemd[1]: Started LSB: WebIOPi initscript.
ps axu | grep python
root 512 1.0 0.7 9584 6716 ? S 15:53 0:34 python /home/pi/therm_sensor.py
root 530 4.9 2.2 138080 21624 ? Ssl 15:53 2:39 /usr/bin/python3 -m myDevices -P /var/run/myDevices.pid
root 580 1.3 1.4 36136 13712 ? Sl 15:53 0:44 /usr/bin/python3 -m webiopi -l /var/log/webiopi -c /etc/webiopi/config
pi 11519 0.0 0.2 4276 1952 pts/0 S+ 16:47 0:00 grep --color=auto python
at /etc/myDevices/Network.ini
[CONFIG]
CayenneApi=https://api.mydevices.com
ServerAddress=cloud.mydevices.com
ServerPort=8181
sudo tail -n 50 /var/log/myDevices.log
2017-08-28 16:46:27 - myDevices - INFO - History CalculateAverages increment: 92
2017-08-28 16:46:27 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘c544d252320a8ae14f01cdf109373f2b64a97b26’: 92}}
2017-08-28 16:46:27 - myDevices - INFO - Save History Averages
2017-08-28 16:46:27 - myDevices - INFO - Memory usage : 106 size: 21624
2017-08-28 16:46:27 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=138.78, ru_stime=17.64, ru_maxrss=21624, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=850237, ru_majflt=19, ru_nswap=0, ru_inblock=12752, ru_oublock=10616, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=67935, ru_nivcsw=13217)
2017-08-28 16:46:27 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-08-28 16:46:27 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-08-28 16:46:29 - myDevices - INFO - Checking update version
2017-08-28 16:46:29 - myDevices - INFO - https://updates.mydevices.com/raspberry/update /etc/myDevices/updates/update
2017-08-28 16:46:30 - myDevices - INFO - Updater retrieve update success
2017-08-28 16:46:33 - myDevices - INFO - No new version detected. Closing update…
2017-08-28 16:46:57 - myDevices - INFO - History CalculateAverages increment: 93
2017-08-28 16:46:57 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘c544d252320a8ae14f01cdf109373f2b64a97b26’: 93}}
2017-08-28 16:46:57 - myDevices - INFO - Save History Averages
2017-08-28 16:46:57 - myDevices - INFO - Memory usage : 107 size: 21624
2017-08-28 16:46:57 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=140.12, ru_stime=17.79, ru_maxrss=21624, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=859103, ru_majflt=19, ru_nswap=0, ru_inblock=12752, ru_oublock=10720, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=68690, ru_nivcsw=13354)
2017-08-28 16:46:57 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-08-28 16:46:57 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-08-28 16:47:06 - myDevices - INFO - SendHistoryData previously SendFailed items:
2017-08-28 16:47:27 - myDevices - INFO - History CalculateAverages increment: 94
2017-08-28 16:47:27 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘c544d252320a8ae14f01cdf109373f2b64a97b26’: 94}}
2017-08-28 16:47:27 - myDevices - INFO - Save History Averages
2017-08-28 16:47:28 - myDevices - INFO - Memory usage : 108 size: 21624
2017-08-28 16:47:28 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=141.37, ru_stime=17.98, ru_maxrss=21624, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=867429, ru_majflt=19, ru_nswap=0, ru_inblock=12752, ru_oublock=10816, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=69578, ru_nivcsw=13450)
2017-08-28 16:47:28 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-08-28 16:47:28 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-08-28 16:47:57 - myDevices - INFO - History CalculateAverages increment: 95
2017-08-28 16:47:57 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘c544d252320a8ae14f01cdf109373f2b64a97b26’: 95}}
2017-08-28 16:47:57 - myDevices - INFO - Save History Averages
2017-08-28 16:47:57 - myDevices - INFO - Memory usage : 109 size: 21628
2017-08-28 16:47:57 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=142.61, ru_stime=18.07, ru_maxrss=21628, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=874510, ru_majflt=19, ru_nswap=0, ru_inblock=12752, ru_oublock=10912, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=70119, ru_nivcsw=13553)
2017-08-28 16:47:57 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-08-28 16:47:57 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-08-28 16:48:06 - myDevices - INFO - SendHistoryData previously SendFailed items:
2017-08-28 16:48:27 - myDevices - INFO - History CalculateAverages increment: 96
2017-08-28 16:48:27 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘c544d252320a8ae14f01cdf109373f2b64a97b26’: 96}}
2017-08-28 16:48:27 - myDevices - INFO - Save History Averages
2017-08-28 16:48:27 - myDevices - INFO - Memory usage : 110 size: 21628
2017-08-28 16:48:27 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=143.95, ru_stime=18.26, ru_maxrss=21628, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=882410, ru_majflt=19, ru_nswap=0, ru_inblock=12752, ru_oublock=11008, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=70862, ru_nivcsw=13639)
2017-08-28 16:48:27 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-08-28 16:48:27 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-08-28 16:48:57 - myDevices - INFO - History CalculateAverages increment: 97
2017-08-28 16:48:57 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘c544d252320a8ae14f01cdf109373f2b64a97b26’: 97}}
2017-08-28 16:48:57 - myDevices - INFO - Save History Averages
2017-08-28 16:48:57 - myDevices - INFO - Memory usage : 111 size: 21628
2017-08-28 16:48:57 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=145.25, ru_stime=18.44, ru_maxrss=21628, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=891265, ru_majflt=19, ru_nswap=0, ru_inblock=12752, ru_oublock=11096, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=71515, ru_nivcsw=13694)
2017-08-28 16:48:57 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-08-28 16:48:57 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-08-28 16:49:03 - myDevices - INFO - Skipping not required packet: 37
2017-08-28 16:49:06 - myDevices - INFO - SendHistoryData previously SendFailed items:
