RaspberryPi MQTT high temp sensor code
Hello,has anyone used a high temp thermocouple amp like the MAX 31855k with a RaspberryPi MQTT? I was looking for code examples to put one together for a Grill smoker temp probe.
Fist, connect you with raspberry pi and get the sensor value https://learn.adafruit.com/max31855-thermocouple-python-library/overview. Once you have succesfully got the sensorr value, add a device to cayenne using cayenne MQTT python library https://github.com/myDevicesIoT/Cayenne-MQTT-Python. then combine got the codes and send the sensor value to cayenne,
Ok, I’ve been unable to get the Adafruit code to work in the past but have been able to get this one to work https://github.com/Tuckie/max31855 do you think this one would work with Cayenne?
Yes, that can work. just publish the sensor value from the above code to cayenne.
Ok, so I would need to get the sensor value from the shell to Cayenne?
yes using this https://github.com/myDevicesIoT/Cayenne-MQTT-Python/blob/master/examples/Example-01-SendData.py
Ok,Thanks. I was thinking would it be best to use something like a Arduino Yun were you would’nt have to worry about powering it down since it would be unplugged and moved often. Ive been looking through code and found the Cayenne-Connections- Yun code.
// This example shows how to connect to Cayenne using an Arduino Yun and send/receive sample data.
//#define CAYENNE_DEBUG
#include <CayenneMQTTYun.h>
unsigned long lastMillis = 0;
		lastMillis = millis();
		//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
	//Process message here. If there is an error set an error message using getValue.setError(), e.g getValue.setError("Error message")
I was wondering if there’s away to clean up and combine theses codes? I’m new to Arduino code and I’m not sure how to make this work.
  This is an example for the Adafruit Thermocouple Sensor w/MAX31855K
  Designed specifically to work with the Adafruit Thermocouple Sensor
  ----> https://www.adafruit.com/products/269
  These displays use SPI to communicate, 3 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <SPI.h>
#include "Adafruit_MAX31855.h"
// Default connection is using software SPI, but comment and uncomment one of
// the two examples below to switch between software SPI and hardware SPI:
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO   3
#define MAXCS   4
#define MAXCLK  5
// initialize the Thermocouple
Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
// Example creating a thermocouple instance with hardware SPI
// on a given CS pin.
//#define MAXCS   10
//Adafruit_MAX31855 thermocouple(MAXCS);
  while (!Serial); // wait for Serial on Leonardo/Zero, etc
  Serial.println("MAX31855 test");
  // wait for MAX chip to stabilize
  delay(500);
  // basic readout test, just print the current temp
   Serial.print("Internal Temp = ");
   Serial.println(thermocouple.readInternal());
   double c = thermocouple.readCelsius();
   if (isnan(c)) {
     Serial.println("Something wrong with thermocouple!");
   } else {
     Serial.print("C = ");
     Serial.println(c);
   //Serial.print("F = ");
   //Serial.println(thermocouple.readFarenheit());
   delay(1000);
Thanks.
is this a separate topic? your issue with pi has been solved?
Hello, sorry the last post should have been a separate topic, I’m still working with the RaspberryPi part.
regarding the Yun topic you need to send double c = thermocouple.readCelsius(); to cayenne using:
	Cayenne.virtualWrite(1, c, "analog_sensor", "null");
Ok, so I would need to put the max31855 code and the Cayenne code together and flash it to the Yun correct?
yes and send the sensor value using above code.
Hello, I think I got it, something like this?
#include <SPI.h>
// digital IO pins.
#define MAXDO   3
#define MAXCS   4
#define MAXCLK  5
//#define MAXCS   10
  delay(500);
   if (isnan(c)) {
   } else {
     //Serial.print("C = ");
     //Serial.println(c);
   delay(1000);
Thanks,Adam.
#14
yes that should work. try removing delay(1000); from main loop.
#15
Ok thanks, would I need to change double c = thermocouple.readCelsius(); to make this read and send the data in Fahrenheit?
#16
double F = thermocouple.readFarenheit();
Cayenne.virtualWrite(2, F, "temp", "f");
and also you need to change:
to
Cayenne.virtualWrite(1, c, "temp", "c");
#17
ok, something like this?
#include <SPI.h>
// digital IO pins.
#define MAXDO   3
#define MAXCS   10
#define MAXCLK  5
//#define MAXCS   10
char username[] = "*************************";
char password[] = "****************************";
char clientID[] = "********************************";
  //while (!Serial); // wait for Serial on Leonardo/Zero, etc
	//Serial.println("MAX31855 test");
  delay(500);
   //Serial.print("Internal Temp = ");
   //Serial.println(thermocouple.readInternal())
#18
yes that will work.
#19
Ok, thanks. On the RaspberryPi side the code would have to be combined with the Max31855 code and saved on the Pi in a file?
#20
Yes you have to save it with .py extension and run it.
