Raspi cannot connect to cayenne
I am using the web dashboard.
What OS? (Jessie, Wheezy)
Wheezy
What Model Pi?
Raspberry Pi Model B (Rev 2.0, 512Mb)
I can install just fine, but the pi never connects to the dashboard.
I see this error in /var/log/myDevices.log:
2016-06-14 16:10:21 - myDevices - ERROR - TestDownload Failed
  File "/usr/local/lib/python3.2/dist-packages/myDevices-0.1.19517-py3.2.egg/myDevices/cloud/download_speed.py", line 47, in TestDownload
    request.urlretrieve(url, download_path)
  File "/usr/lib/python3.2/urllib/request.py", line 151, in urlretrieve
    return _urlopener.retrieve(url, filename, reporthook, data)
  File "/usr/lib/python3.2/urllib/request.py", line 1602, in retrieve
    block = fp.read(bs)
ValueError: read of closed file
Can you run down through this post and report back? Troubleshooting Pi Showing Up as Offline in Dashboard
Yes,
I already ran through all of those items.
Interestingly, the iPhone app is working, but it shows as ā€œofflineā€ from work.
Are there any special ports that need to be opened on the browser side?
I donā€™t have an iPhone to test with, but I would think you most likely have port 8181 blocked at the router. @bestes can confirm but since the iPhone and Android apps work locally they probably donā€™t need to go to the cloud server and they send/receive all data on the LAN.
Can you post the output from the post I linked?
As @ats1080s mentioned, it may be issue with the network you are on at work. Iā€™ve talked with Cayenne team and that error should not affect ability to connect to Cayenne dashboard.
Can you update us after trying on your home network? Posting the output would also be helpful.
Itā€™s clearly something at my work.
I can connect just fine from home.
This brings up more questions about how the dashboard works.
I assume that the raspi reaches out to cayenne/mydevices servers and reports itā€™s stats periodically over port 8181, and then my browser connects to cayenne/mydevices web server to read the values over port 443.
I would assume that thereā€™s some AJAX call to do that, and uses some HTML5 object to show the gauge.
What I donā€™t understand is what would be getting blocked at work.
Does it use a different port than 80 or 443 to connect to cayenne.mydevices.com, or does it use some other hostname to pull that data?
I guess another thing to check would be IPS, so see if something is being caught there. Iā€™ll double-check those logs tomorrow.
Hi @baldwintm_iot,
Iā€™m going to move this topic to Helped category :slight_smile: Hope you donā€™t mind.
So your assumptions are correct. We use 443 to cayenne.mydevices.com, but we open websockets at 5001/2, so that might be where itā€™s blocking at your work.
Hope this helps :slight_smile:
@bestes,
That was the answer that I needed!
Thanks for having the right information at the right time!
My pleasure!
