Raspi Zero W Installing Library Stuck
Hi there,
I’m new to MyDevice and I try to setup my Raspberry Pi Zero W.
I followed the First Installation procedure, in particular I used the script to install MyDevice.
My Raspi download the package and start the installation procedure.
After the reboot, if I log to my account, I see that the libraries installation is in progress. But this process is stuck. After one night, it seems blocked.
Where I went wrong?
I use Raspbian Lite. Which version of Raspbian should I use?
Thank for the help!
Try running these commands before running the install script again
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get install python3.4
sudo apt-get -f install
In addition, if it is still stuck after running those commands on the Pi, show us the output from the Pi command line on your next installation attempt – this will help to troubleshoot any ongoing errors.
