Relay Unreachable on platform / Arduino ESP8266
I am new with Cayenne device.
I want to controle a relay with an arduino mega and ESP8266.
Using the web platfom, I have the message telling that the relay is Unreachable. But with IOS platform it works.
I put a screen shot and here is the code I have in the arduino:
Steps:
#include <OneWire.h>
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define EspSerial Serial1
#define VIRTUAL_CHANNEL1 4
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define SENSOR_PIN 7 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL2 7
OneWire oneWire(SENSOR_PIN);
ESP8266 wifi(&EspSerial);
  delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  delay(10);
  sensors.begin();
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_OUT(VIRTUAL_CHANNEL2)
  Cayenne.celsiusWrite(VIRTUAL_CHANNEL2, sensors.getTempCByIndex(0));
  //Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL, sensors.getTempFByIndex(0));
CAYENNE_IN_DEFAULT()
CAYENNE_IN(VIRTUAL_CHANNEL1)
  int value = getValue.asInt();
  CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL1, ACTUATOR_PIN, value);
  if (value == 0)
  digitalWrite(4, HIGH);
  else
  digitalWrite(4, LOW);
try to add the Mega using Bring Your Own Thing.
Read this: Arduino MQTT offline
@loic.tachon give this a try.
