Release Notes March 21, 2018 - 4 NEW Widgets and Bug Fixes!
Hello Cayenne community!
4 new widgets for you to use in your projects! Tank Level (very cool), CO2, Motion, and Proximity.
You can use these widgets with your mqtt and Arduino devices. Simply add them by going to the ‘Custom Widgets’ section in the Cayenne add device process.
General Bug Fixes
As always, thank you for reporting any issues you come across while using Cayenne. We always do our best to resolve them quickly, while balancing new feature releases :slight_smile:
  • Removing a widget does not remove the widgets from projects view (causes issues)
  • Icons & names on the left device panel do not match the widgets the dashboard
  • GPS widget doesn’t display GPS points after being added…refresh is required
  • Fix to the “last data packet sent” field for each device
  • Fixes to device data console feature
  • Fix to device search box
good night grateful for the new widgets but of little use if the thrillers do not warn of any anomaly. Thank you
Nice to see some speed improvements to platform, and some new widgets dont know why we need them yet since major issues are still open.
1.Actuators dont work on mobile application (android), just from browser.
2. Most of the things are in total inconsistency between phone application and web/desktop
3. Schedules and triggers
4. Random dashboard resets from value to graph gauge display style.
5. When mobile application is started it shows - on widget for a dashboard values until it receives data from connected device, its not problem for users who send data every 3 or 5 sec but for us who send data in 30 od 60 sec timespan its kind of annoying.
6. New projects created on mobile application, dont show when you open dashboard on web browser.
7. Project and dashboard values dont always show the same data values when you switch from one to other until you refresh page.
Not so important just a notice last phone application update does not contain new widgets in the list.
Suggestions for improvement:
When sharing project to someone, if he opens link on his phone he can not view it because of play store pop over blocking it. It can be done by using view desktop site option, but not every one are tech savys, it needs to be simple to use. If they download the application they can not use shared link with it so there is no actual ussefull thing from taht pop over.
Remove that pop over blocking the shared view for smaller screen, implement something like a bar at the bottom for the link to application.
Relays Synchronisation
