I don’t seem to be able to delete a scheduled task that I no longer need to use, but can’t find a delete/remove button anywhere can anyone help a noob with this noob question
Hi @dar_c, no worries. You can delete a scheduled task by going to ‘User Menu’ in the upper right, then ‘Scheduling’. This will bring up an event calendar. When viewing the calendar, you can click on a day and it will show a list of events, and each will have an X to delete it:
You can also click on the individual events on the calendar to open the ‘Edit Event’ window for that task, and that will have a ‘Remove Event’ button as well.
Thank you for your help seems they slide to the right and the button appears thanks for pointer very helpful…
Hello @rsiegel ,
I can not delete some scheduled tasks. When I try delete it a popup message where says " Could not remove event" Could you help me?
Attached two screenshots
Thank you
will have it removed.
I have a problem to delete a scheduled task. I haven detected the problem when i can not delete. The problem is space " " or symbol like - _ .
Could you help me to delete those tasks?
- [Encendido Alimentacion Pozo (08:40)]
- [On Interruptor Pozo (08:45)]
- [Diario_cantero (10:05)]
- [Diario_offmorning (10:05)]
