Retropie - Dependencies problem when installing mydevices script
Hi
I have dependencies issue when I run connect script of mydevices on fresh install retropie
Correcting dependencies… failed.
The following packages have unmet dependencies:
expect : Depends: tcl8.5 (>= 8.5.0) but it is not installed
libexpat1-dev : Depends: libexpat1 (= 2.1.0-6+deb8u1) but 2.1.0-6+deb8u3 is installed
libjpeg62-turbo-dev : Depends: libjpeg62-turbo (= 1:1.3.1-12) but 1:1.4.1-2 is installed
xfonts-base : Depends: xfonts-utils (>= 1:7.5+2) but it is not installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Anyone have the same problem?
Hi @leal, welcome to the Cayenne Community,
Currently the Cayenne Pi agent supports Rasbpian Jessie and Jessie Lite, so you may want to try one of these OS instead of Retropie.
Alternatively, instead of using the Cayenne Pi agent software to connect your Pi to Cayenne, you could do so via our ‘Bring Your Own Thing’ MQTT API which frees you of the limitations of the Pi Agent software. Have a look at this example which shows connecting a Pi via MQTT rather than the Cayenne Pi agent software.
Retropie is raspbian Jessie.
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs
Do you know how to solve those dependencies?
I’m not sure if this will work or not…but you can try this
sudo apt-get install tcl8.5 xfonts-utils
The other two have newer versions installed so you might be able to get away with it. Let me know if that works.
Hi
I try to run:
But not working.
I think when I installed agent for mydevices something goes wrong and apt-get install command not woking at all. I also try to run:
sudo apt-get -f install
And I get same error:
Reading package lists… Done
Building dependency tree
Reading state information… Done
thx you for trying to help.
Do you have any further suggestions?
If I run command:
before I install agent form mydevices I get less depenencies problems
Hmm looks like the installer doesn’t like that newer version. If you downgrade it will likely break retropi. I would recommend getting a second SD card and installing the full version of Jessie.
