Sending 4 bytes data with Lora
Hi, I’m using a Lora rak811 module. I need to transmit an ADC data using at least 4 bytes.
As I could see in the Cayenne documentation, an analog data has just 2 bytes. Do you know if there is any way to change this and send a 4 bytes data?
Hi @ezequiel2188,
It appears we currently only support 2 bytes of data for Analog Input: Sending 4 bytes data with Lora
Can you provide some examples of data you’d like to send?
Thanks.
@jcruz or @croczey might be able to help
Thanks for answering.
I need to send voltage data from an ADC, and using 2 bytes it is not accurate enough.
