Sensor Tutorials
Would be great to get a bit more information on the page where I can add sensors, added a onewire device and was forced to enter a slave value, not sure what it was but also know I cant change whatever value I put in there
Hi Chaun,
Yes, this is something that is in progress. We will be adding tutorials and other helpful information for each sensor.
If a 1-wire sensor is properly configured to GPIO pin 4, we actually automatically detect it and add it to the dashboard for you…maybe try this out for the 1-wire you are trying to add?
~B
Will do, what info should be added to slave as I see it’s a requirement before I can continue.
Also, does it allow for multiple onewire devices to be added on the same line?
