Seperate programming of esp8266
Can we program esp8266 seperately using ttl converter and then integrate with arduino mega so that i can add sensors to mega and monitor through cayenne dashboard
@matrix.khan14,
Yes you can. Just make sure you load a compatible AT command firmware and use the ESP shield example in the library modified to whatever Mega serial port you connect the ESP to:
Thanx… This helped …
