Sharp dust sensor
Hello.i use a Sharp Dust Sensor GP2Y1010AU and i’d like to know if there is a way to set up this sensor and how on the thank you .
Hi
The only possibility is Arduino.
Yes i’m using it. I mean if cayenne team can add my sharp sensor to the others on the cayenne sensor.
Just write the code and add it as a Custom Widget on Cayenne Dashboard.
Do you have any code to output to Serial port?
At moment i’m using the sharp code added to the cayenne code and seems to be ok.i use Arduino uno and ethernet shield.
Great
You can share the code please?
