Signal strength wifi
Hello community.
as part of a small project requiring a strong signal.
For a NODEMCU how to insert the function RSSI.
I tried without success.
this part of code that does not work!
// # define CAYENNE_DEBUG
char ssid [] = "............";
char wifiPassword [] = ".....................";
char username [] = "..............";
char password [] = "....................";
char clientID [] = "................";
#define VIRTUAL_CHANNEL 0 // RSSI
long rssi = WiFi.RSSI ();
void setup ()
   Serial.begin (9600);
   Cayenne.begin (username, password, clientID, ssid, wifiPassword);
void loop ()
   Cayenne.loop ();
CAYENNE_OUT (0)
   Cayenne.virtualWrite (0, RSSI, "RSSI", "dbm"); delay (2000);
thank you in advance.
@zanni.robert you can try this code excluding the oled code https://github.com/wifijt/SSID_RSSI_BSS_OLED
Bonjour shramiksalgaonkar.
I will try to clean the code.
THANK YOU
Robert
