Sketch File generation!
Thank you in advance for taking the time to let us know about your Ideas. We truly value your input and discuss each Suggestion as a team. It would be most helpful if you could include a use case for your Idea (how it will solve a problem, or add to the usefulness of Cayenne as a proto-typing solution). Thanks!
HELLO THERE.
SO basically I am writing this as an Ideas/Suggestion, but I believe might be a little bug/mistake. In the generating Sketch file from the Add Device/Widget the popup window doesnt draw the pin selection properly. I have used the Virtual pins and it always uses V1. It is not a big deal, but it should be no problem generating the code to draw the proper Pin selected from the combobox.
Hi @vladbills,
Thanks for the suggestion! This is coming soon :slight_smile:
~Benny
This has been done.
~Benny
