Slide bar can not connect to arduino
Hi.
I am new to Cayenne Community.
I want to control an RGB with 3 slide bars, one per color. My problem is that I am not able to send the information from the slide bar to arduino.
I can swich on a Led with a button from cayenne, but cannot go any further.
Could anybody help me with the steps I have to follow, please?
Thank you in advance
My code:
#define EspSerial Serial2
ESP8266 wifi(&EspSerial);
#define VirtualRED 11
#define VirtualGREEN 10
#define VirtualBLUE 9
#define RED 11
#define GREEN 10
#define BLUE 9
#define LEDPin 2
#define PIRPin 7
#define Piso1  7
unsigned long TapagadoPIR;
unsigned long tiempoPIR = 8000;
unsigned long Tserial = 0;
int rojo;
int verde;
int azul;
  Serial.begin (9600);
  delay(10);
  EspSerial.begin(115200);
  delay(10);
  pinMode(LEDPin, OUTPUT);
  pinMode(RED, OUTPUT);
  pinMode(GREEN, OUTPUT);
  pinMode(BLUE, OUTPUT);
  int valuePIR= digitalRead(PIRPin);
    analogWrite(RED, rojo);
 CAYENNE_IN(VirtualRED)
  rojo = getValue.asInt();
  CAYENNE_LOG("Channel %d, value %d", VirtualRED, rojo);
There was a known issue with sliders in the mobile app for some time. @shramik_salgaonkar do you know if that has been fixed yet?
Yes there was issue with slider but in this case from the dashboard it looks like the device is not online. @alex1alonso did you add device to cayenne using “Bring your own thing” ?
