Slider function as a on off swits
Hai there. I am a new beginner at Cayenne. My first project fails and i hope to solve it soon. I have use a slide for controlling a led but when i measure or use the D3 or any other PWN pin starts the trouble.
when the slider is on 0 led off but when on 1 it is full on. slider reacts as a switch ( on or off ).
i want to use it to control a rgb led. Please can you help me.
using web and mobile app
used uno and mega with 2 different 5100 lan shield
measured output current ( gives 4.68 volt and stays that way untill off or 0 )
By Frank!
Hi Frank,
Could you share with us the sketch that you’re using to interact with Cayenne? And a screenshot of the settings page for the Slider widget you’ve created in Cayenne?
[https://dl.dropboxusercontent.com/u/51943663/screen%20slider.jpg]
standard skets nothing changed, my token is now xxxxxxx☺
Steps:
#include <CayenneEthernet.h>
char token = “xxxxxxxxxx”;
Cayenne.begin(token);
This is what I needed to do to make the slider work:
float currentValue = getValue.asDouble(); // NOT getValue.asInt()
currentValue = currentValue / 1023; //Divide the received value by 1023
Now, the float variable currentValue holds the input value, and can be used at output for instance to a PWM pin:
analogWrite(LED_DIGITAL_PIN, currentValue); // must be from 0 to 255
Just enable custom range on slider widget and give 0 to min and 4 to max with using example slider sketch.
This can result a linear pwm
Hi.
I am new to Cayenne Community.
I am also having a somewhat similar issue but with a little change.
I am using an LED on pin-11 of Arduino MEGA with W5100 ethernet shield on PWM application. The custom range of slider that i set on my PC dashboard is 0 to 255 and it works fine with PC but when it comes to android app. it shows range 0 to 1 instead of 0 to 255. That is, its either 0 or 1.
Any help on the issue would be really appreciable.
Thanks.
Sarwar.
