Slider problem
i add a slider in cayenne android app but when i want to change its value after 2 sec it sets itself to max slider value . pls help me and sry for bad english.
i am using nodemcu but i think it doesnot matter with problem.
can you share the code, screenshot of your dashboard and if possible a video of the same.
i made a fresh device in cayenne app and i add a slider in it and once i connect it to a CAYENNE_IN func and also i made another one slider and i did not connect it to CAYENNE_IN and both of them worked but also both of them has a problem … when i change its value, after 2 sec its value change to max and i screenshot them as blow
ty
after 2 sec :point_down:
this is my code
This example shows how to connect to Cayenne using an ESP32 and send/receive sample data.
Steps:
1. If you have not already installed the ESP32 Board Package install it using the instructions here: https://github.com/espressif/arduino-esp32/blob/master/README.md#installation-instructions.
2. Select your ESP32 board from the Tools menu.
//#define CAYENNE_DEBUG
    #include <SimpleTimer.h>
    #include <OneWire.h>
    #include <ESP8266Ping.h>
    char ssid[] = "";
    char wifiPassword[] = "";
    char username[] = "1";
    char password[] = "";
    char clientID[] = "";
    unsigned long time1;
    int autoMode;
    int tempSlider;
    #define RelayPin 13
    #define RelayPin2 14
    #define DS18S20_Pin 12 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
    //Temperature chip i/o
    OneWire ds(DS18S20_Pin); // on digital pin 12
    SimpleTimer timer;
    const IPAddress remote_ip(8, 8, 8, 8);
    // This function sends the device's uptime to Cayenne on Virtual Channel 5.
    void sendUptime()
      // Send values using the virtualWrite function. Cayenne currently accepts int and float values.
      // Please don't send more that 10 values per second.
      Cayenne.virtualWrite(0, getTemp());
      Serial.print("ping = ");
      Serial.print(remote_ip);// print as an ASCII-encoded decimal - same as "DEC"
      Serial.print(" ");
      Ping.ping(remote_ip);
      Serial.println(Ping.averageTime());
      Cayenne.virtualWrite(5, Ping.averageTime());
      Cayenne.virtualWrite(7, tempSlider);
      if( digitalRead(RelayPin) == LOW){
        Cayenne.virtualWrite(2,1);
      else {
        Cayenne.virtualWrite(2,0);
      if( autoMode == 0){
        Cayenne.virtualWrite(4,0);
      else {
        Cayenne.virtualWrite(4,1);
    void autoCheck()
      if(autoMode == 1){
        if(getTemp() >= tempSlider && getTemp() < (tempSlider+1)){//on
          CAYENNE_LOG("autoMode : KOND!");
          digitalWrite(RelayPin, HIGH);
          delay(1000);
          digitalWrite(RelayPin2, HIGH);
          delay(1000);
        if(getTemp() > (tempSlider+1)){//tond
          CAYENNE_LOG("autoMode : TOND!");
          digitalWrite(RelayPin2, LOW);
          delay(3000);
          digitalWrite(RelayPin, LOW);
          delay(1000);
        if(getTemp() <= (tempSlider-1)){//off
          CAYENNE_LOG("autoMode : OFF!");
          delay(3000);
          delay(1000);
      time1 = millis();
      autoMode = 0;
      tempSlider = 25;
        // Set up a function to be called every 5 seconds
      timer.setInterval(1000L, sendUptime);
      timer.setInterval(5000L, autoCheck);
      pinMode(RelayPin, OUTPUT);
      pinMode(RelayPin2, OUTPUT);
      timer.run(); // Initiates SimpleTimer
    CAYENNE_OUT_DEFAULT()
      //Cayenne.luxWrite(2, 700);
    CAYENNE_OUT(0)
      //Cayenne.virtualWrite(0, getTemp());
    CAYENNE_IN_DEFAULT()
    CAYENNE_IN(1)
      if(millis()-time1 > 3000){
        if (getValue.asInt() == 0) {
          CAYENNE_LOG("OFF : %u", millis());
         delay(3000);
        else {
          CAYENNE_LOG("ON! : %u", millis());
          delay(3000);
        time1 = millis();
      else{
        CAYENNE_LOG("!!!!!!!!!!");
    CAYENNE_IN(3)
        if (getValue.asInt() == 1) {
          autoMode = 1;
          CAYENNE_LOG("Automatic ON! : %u", millis());
        else {
          autoMode = 0;
          CAYENNE_LOG("Automatic OFF : %u", millis());
        time1 = millis();
      else{
    CAYENNE_IN(6)
        tempSlider = getValue.asInt();
    float getTemp(){
     //returns the temperature from one DS18S20 in DEG Celsius
     byte data[12];
     byte addr[8];
     if ( !ds.search(addr)) {
       //no more sensors on chain, reset search
       ds.reset_search();
       return -1000;
     if ( OneWire::crc8( addr, 7) != addr[7]) {
       Serial.println("CRC is not valid!");
       return -1000;
     if ( addr[0] != 0x10 && addr[0] != 0x28) {
       Serial.print("Device is not recognized");
       return -1000;
     ds.reset();
     ds.select(addr);
     ds.write(0x44,1); // start conversion, with parasite power on at the end
     byte present = ds.reset();
     ds.select(addr);
     ds.write(0xBE); // Read Scratchpad
     for (int i = 0; i < 9; i++) { // we need 9 bytes
      data[i] = ds.read();
     ds.reset_search();
     byte MSB = data[1];
     byte LSB = data[0];
     float tempRead = ((MSB << 8) | LSB); //using two's compliment
     float TemperatureSum = tempRead / 16;
     return TemperatureSum;
Thanks for reporting this issue. We are working on it and will let you know once solved ,.
