Sliders wrong on mobile app
    ESP8266 wifi
    both web and android
whena slider is added on web looks like this (good):
but on andoid app the slider shows different and it could not be changed¡¡
looks like this ( bad only from 0 to 1):
just only for notify the bug.
you can change the slider maximum position by clicking on the setting (gear icon).
confirm that the issue persist, not a matter of change the values on the sliders because the values from 0 to 255 are defined on the app.
I just tried on a second project and fails too:
and on the app:
if I change again on the app the change not apply it.
